Posted February 10, 201015 yr Pleze help me !!!When i put my boot screen files in one piece updateold bootscreen appearsand i tried to put them in ricktendo64 vista bootscreen addone by replace his files with my filesTo make addon like ricktendo64and same problem .... old boot screen appearsalthought ricktendo64 files run well but my files noWhat problem Here???My addonhttp://www.mediafire.com/?jjtaodejugy
February 10, 201015 yr it might be cause u use an old kernel version "5512"latest kernel version is "5857"
February 10, 201015 yr Take the latest krnls from the updatepack you are using and patch them, then make a simple entries_whatever.ini with just the name and other info and you zip them all together.
