Forum is upgraded to v2.2.2
We have problems with account activation, modules that have to be reinstalled and skin problems.. We're working to resolve upgrade issues.
Upgrade log:
IP.Board 2.2.2 Bugs Fixed
eaccelerator and updating skin wrappers
Upgrade
IPS Driver Error
Sql Problem with ibf_topic_markers
IPB WARNING (array_merge, foreach)
Require Error Due to Unchecked Input in Profile
Editing Members (IPS Driver Error)
Subscription manager delete members issue
Linked images in PM's not resizing
Custom fields on reg screen in IE7
Still a bug with quick topic title edition
Help topics bad HTML Output
allow_sub_select in sql_error_log
Personal Statement text messed diacritics
Encoding not sent for iframes when editing html templates
[2.2.1] Editing Categories (MySQL 5)
Using pagination where field of the input is not st
Last post links and pagination for outline view
Profile Behaiviour
PHP Fatal error
Images
Images On Another Server
Some other charset problems...
rss_import_url data type
Settings for group: Display Name Settings
Search Members->More Options: Gender entry shown even when using classic profile mode
url in quote tag bug
Thumbnail IE line breaking code logic flaw
Banned Filter doesn't work with UTF-8 Chinese Characters
Custom BBCodes: Parsing errors when giving empty arguments
PM address book
Possibility to edit post without leaving "Edited by"-tag and merge action not saved in moderator logs
quote code errors
Upgrade wizard issuess
Date missing in subscription expiration email
Skin bugs (2.2.1)
Gaining Root Admin with a Admin Account
Rss import problem with other charset (logical problem)
Pruning forums -> double entry in mod logs
emoticons double parsed?
user profile rendering bug under Safari
multibyte: comment wordwrap
No email on new topics in RSS-forum requiring moderation
RSS import: 100 max per feed hardcoded
CSS Bug
PM Percentage Bar
Old bug still not fixed
IP.Board 2.2.1 - Topic View - Online Image & Long names - line break problem
Line doesn't break in Interests field
Staying logged in (finally, the actual issue?)
Exchanged icons, I'm still confused
Problem with topic description quick edit
A very small issue
Buggy input check in install's address action
Portal enabled through init.php, cannot access forum
popup windows and focus()
Post view usability when cross-linking: Useless link to post with JavaScript disabled
Lost Attachments on Topic Merge
Bug with Lo-Fi and attachments
Emoticon Limit
Mysql error for google bot
Approving member leaves member in Awaiting Auth.
IPS Client Area in Help & Support tab (IE7)
Multi-lined settings thinking they are not default
Member #8 Could not be a Moderator with group #8
Forum rules doesn't accept two link at one line
ban filter - email
Captcha last digit sometimes off image
[2.2.1] Import Languages_xml
[2.2.1] Profile View - "Post Count" and "Active" fields not displayed for some members
Long links in RSS export broken
skin bug
Apache going crazy at Security and Privacy settings page
ACP Restrictions
<script> Bugs inside [HTML]
IPB 2.2.x [HTML] Attributes not properly higlighted
IPB 2.2 Multi-line HTML comments not red in [HTML /]
First line of code tag
PM CC Member Error
api_settings does not import Setting Group Module
Profile Offset Error
Forum announcement
Skin_Store_ contains extra columns in caching db_skin
tar.php regression
2.2 Photo Upload error
Generate key error
Error displaying image attachment with extension .php.png in post
Stripslashes Missed When Click Go To Full Editor
Classic profile view: Excess linefeeds in custom profile fields (text)
Text aligning works in signatures with bbcode disallowed
URL Avatar didn't appears
Render Row Misplaced Tag
Error when sending saved pm
Admin Restrictions>Management>Members>Blank Row 4th down
Attatchments Space
graphics attachmt not enlargeable in editor preview
Comments in profiles repeating.
Viewing Profile->Comments, Check comments and delete comments
xml_char used 2 times in same file
Error in comments
"Last Seen:" time on new profile portal
Email From: doesn't accept diacritics
Incorrect subhect encoding
Topic Subscription Reply Notification
HTML Meta Tags
HTML adding tags
skin output formatting
CSS UCP
2 image errors showing up in cPanel error logs
Profiles set to classic - but extended still visible
[2.2.0] Upgrading from version 1.3
10003 Upgrade Bug
CSS Font Spaces
small hardcode in class profile mode
Possiblke mis-spelling on ACP > Security & Privacy > Enable Captcha?
IP Member Tools
Guidlines
Simple Spelling
Secondary groups and unlimited PM storage
Using eaccelerator & updating skins
stats keep reseting after upgrading to 2.2.1
[2.2.1] One remaining PECL APC bug?
Exclamation Marks not Parsing in P.P.'s Interests
Double Comments while Pending Approval
Impossible birthdays
[IP.Board 2.2.1] System Overview showing wrong Version of IPB
Odd character set issues
Attachment Thumbnail Display
2.2.0 - Friends List in PM Box now block list
[2.2.1][MSSQL - Search Doesn't Work With Two+ Words
[2.2.1] Fatal Error In ACP Clean-Up Tool
[2.2.1] Posting Comments
Is this a bug?
Unserializing cache values is broken if using local cache
PM error in 2.2.0 final
Login Auth
[2.2.0]Bug with insert special items
HTML in reported post pm
2.2 Enabling Portal Breaks Announcements
2.2.0 Search Bug?
Rebuild forum's posts
Who's Online In Chat
Post any bugs or upgrade issues here.
