Good morning.
As for custom themes that I have saved on time in personal themes, I wanted to know which path is nestled on my theme, because I save it to another medium to be able to restore from the format.
I went in the path C: \ Windows \ Resources \ Themes but I've found, where the hell you hiding?
Thanks
If you saved the theme.
The actual .theme file will be in
C:\Users\(your user name)\AppData\Local\Microsoft\Windows\Themes....
However... That will ONLY be the .theme file....
If your wanting to be able to restore them after a format, you need to save the theme "for sharing"
When your in the control panel goto personalization....
Right click on your custom theme and choose "Save theme for sharing"
It will allow you to save the theme as a "themepack" file....
Then after you format, all you have to do is double click on your whatevername.themepack file
and it will be installed....
