Posted February 18, 201015 yr Hello !!!I'm new in this area, well I just would like to know if I edit the file : syssetup.infShould I Install The windows XP with out a reboot.. I mean Just Update with out put the S>E>R>I>A>L # by my self??, I just know how to do it using nLite :dribble: ; but like this only works making Boot and formatting The Hard Drive. and I want it to works both ways.ThanksIf This Will Be my solution.... Could somebody explain me how to do that?Where should I Put the S>E>R>I>A>L #.Thanks a lotI hope any of you can solve my question. :manual: AL RATO !!! Edited February 18, 201015 yr by Wanako1
February 18, 201015 yr Hello !!!I'm new in this area, well I just would like to know if I edit the file : syssetup.infShould I Install The windows XP with out a reboot.. I mean Just Update, not making Boot and formatting The Hard Drive.If This Will Be my solution.... Could somebody explain me how to do that?Where should I Put the S>E>R>I>A>L #.Thanks a lotI hope any of you can solve my question. :manual: AL RATO !!!well editing the syssetup.inf i don't understand how would it install XP without reboot it's not possible as i knowbut about the serial part you would need to type it in winnt.sif more info hereor use nlite to do that for youEdit: i don't know if that what you want or not but after you edited your post do you want to enter the serialso it would be silent when you install from another windows or ?please explain more Edited February 18, 201015 yr by DaRk MaDnEsS
February 19, 201015 yr Author Ok. I will try to explain better....What I want to Know is: If can I edit something to Install my windows XP with out Reboot ??Thanks means... for example, when you insert the Windows CD into your Tray.. the setup work automatic right??And you can choose any option that that menu gives you..Ok I want the Option : Install Windows XP Professional .... And start to Load the CD But after that This will ask you for Serial #. I don't Want That !!! I Want the Option that start and Do not ask you any serial #...So this can be Installed By Reboot and Update too. :thumbsup_anim: It's better explication???Thanks a Lot to everyone !!
February 19, 201015 yr It will be easy to do this with nlite, and wihtout rebooting it is not possible in my opinion.
February 22, 201015 yr Author I think is not possible...So let's say is not possible the way I want... anywaysThanks a lot to everyone.Al rato!!!! :thumbsup_anim:If you Edit SYSSETUP.DLL Will Work.I Find The Way Already. :sweatingbullets: :naughty:I'm Sorry if i said With out Reboot,I Mean Update the Windows XP.now is Clear like used Oil... :dancing: Edited August 14, 201113 yr by Wanako1
