Vista2XP [Visual] Packs ENU/FRA
Hello everybody!
In advance, sorry 4 my english level. I try to do my best.
After almost 1 year ½ of searching/learning/optimizing, i'm very happy to share this work with u : the Vista2XP Packs.
Nota : The retro curves in picture above have been created with Photoshop CS3. Tuto >>> Mix Cool Retro Curves Into Your Photographs written by Fabio, member of excellent site PSDTUTS.
SPECIAL BIGS HUGE THANX
To wallace87000 (my eternal hommy), for his encouragements & to Vivi, for her tenderness & so on, so on.
THANX TO
TECH NOTES
For the Vista2XP Pack #1 - Sample Pictures, I've used a trick like Vista's files localization/translating.
PREREQUISITES :
  • Alky For Applications v1.1 (XP version)
  • Restorator2007/2009 (shareware) | Resource Hacker v3.4.0.79 / Resource Hacker v3.5.2 Beta (freeware)
  • A non registrable, without resources DLL (it's my departure point to create Xtr3mAddOnRes.dll)
  • Images/Pictures (from Vista/Se7en or others, as you like. See listed sites above)
  • Following Vista's files:
    • %SystemRoot%\System32\SampleRes.dll
    • %SystemRoot%\System32\en-US\SampleRes.dll.mui --> (MUI Dir name depends on your Vista native english : en-AU|BZ|CA|CB|GB|IE|JM|NZ|PH|TT|US|ZA)
    • %ProgramFiles%\Windows Photo Gallery\PhotoLibraryResources.dll
    • %ProgramFiles%\Windows Photo Gallery\fr-FR\PhotoLibraryResources.dll.mui
    ************** Don't worry : details will follow later. ************:
    %SystemRoot%\Resources\Xtr3mAddOneRes
    Not enought clear?
    Ok. Open My Computer, and follow guide in images :
    After that, click on Start ---> My images & open link Sample pictures
    Now, you can see a hide file named Desktop.ini : it contains images names (in english) & the paths (pointers) to file resources translated (here %SystemRoot%\Resources\Xtr3mAddOneRes\fr-FR\SampleRes.dll.mui have localized files name (in french) [i.e, creek.jpg = Rivière.jpg = resource 101 --> in SampleRes.dll.mui].
    Make a test like this : comment any line of file Desktop.ini, save modifs & refresh (Key F5 on keyboard) or close window & reopen it. ...Appreciate!
    This feature can also apply to others Vista2XP Packs.
    PS : If u prefer, u can choose an easier way to translate : "by combining" CopyFiles & Strings sections (like I do in Vista2XP Pack #3)
    CopyFiles Section
    [strings] Section <--- No ID = default language [ here en-USA = English(USA) ]
    Section [strings.040C] <--- 040C = fr-FR language ID = Français(France)
    Vista2XP Packs are XP customization/replacers addons based on Vista's resources & work on sme way : replacement (with/without backup) XP files with ones from addons.
    At the biginning, it was a AIO bilingual (ENU/FRA) addon for my own use. But, I decide, 9 months ago, to also create some standalone packs (Read MY REQUEST HERE ---> in french :blush: ) and to share all with the members of upd.fr, my 1rst community on the net.
    But, due some help I've received on script rewritting from various sites members,I decided to share my work with a largest communauty :icon_cool:
    Addon(s) is(are) available (u've choice) as :
    • AIO Pack :
      MD5 : 36B482F5316B9463C9E98EBEF895102B
    and StandAlone packs below:
    • Pack Vista2XP #1 : Sample Pictures ( images sizes : 1024x768 | 1600x1200 )
      Default Pictures
      replacer
      Images from Vista
      Images added
      Sample Pictures Backup Dir (%AllUsersProfile%\My images\Sample Pictures)
      MD5 : 55BD42F586B4A78E1A31ED4B11A26985
    • Pack Vista2XP #2 : Screen Savers
      PREREQUISITE : OPENGL32.DLL (included in WinXP, in addon & copied to %windir%\system32)
      Default Screen Savers
      Replacer
      Added
      Screen Savers Backup Dir (%SystemRoot%\system32)
      MD5 : 727FF439919C52878355D48C7DC61C86
    • Pack Vista2XP #3 : User Account Pictures (Avatars) ( images sizes : 128x128 )
      PREREQUISITES : Windows Script 5.6
      Defzult UAP
      Replacers
      Added
      Avatars backup Dir (%AllUsersProfile%\Application Data\Microsoft\User Account Pictures)
      MD5 : C1E9AD6BB52E6096E211B79E90A6169A
    • Pack Vista2XP #4 : Wallpapers ( images sizes : 1024x768 | 1280x1024 | 1600x1200 | 1920x1080 | 1920x1200 | 1920x1440 )
      Default Wallpapers
      Replacers
      Added
      Wallpapers Backup Dir (%Windir%\Web\Wallpaper)
      • Windows Movie Maker : ( images sizes : 640x480 | 640x360 )
        MMaker Default Images
        Replacers
        Added
        MovieMaker Backup Dir (%ProgramFiles%\Movie Maker\Shared)
      MD5 : A9DA99A24374AEB2A29C44BA064EC155
////////////////////////////////////::: INSTALLATION/UNINSTALLATION ::://////////////////////////////
NB : Install/uninstall dialogs/messages/prompts may be differents as ones visibles on snapshots available in topic. It's normal : I'm tryin' to make them more "professional".
All Packs are installable/uninstallable by Add/Suppress Windows Component fonction
And a prompt message displays, giving u the ability to check ( and thus to remedy it) that no file from pack whose have uninstallation in progress is in use.
If u click on :
  • Cancel : System will consider the componant as uninstalled; but really, it is false. ( TO FIX ).
  • OK : opens Display Properties Window on tab (in case of pack #2) Screen saver. By caution, choose (NONE). U can change/modify after uninstallation of pack.
///////////////////::: PARTICULAR CASE : Vista2XP Pack #3 :::///////////
During installation/uninstallation, u can choose to de modify/change your avatar :
WARNING : during uninstallation, please follow procedure below :
If u click on :
  • Cancel, nothing happens.
  • OK, script %windir%\Resources\Xtr3mAddOneRes\Scripts\Avatars.js starts & Choose a new picture for your account window appears (Timeout = 15 seconds):
  • NB : WAIT until u see Vista2XP Pack #3 window files deletion
  • After that, double-click on any avatar & close all others windows.
  • If u double-click on an image before deletion of Vista2XP Pack #3 files, your account will keep an avatar from Pack #3.
  • To fix it, click on 'Start' button ---> click on the image near your username
  • Now, choose any avatar. Voilààà...
Edited by Ken@fri
Hi!
Ok, the last pack (Pack #4 : Wallpapers) is online.
I also fixed a minor bug in file Vista2XP from AIO Pack (without that,Vista2XP Pack #4 - Official Wallpaper.jpg won't be copied during integration.)
Bye ;)
Edited by Ken@fri
