Now ANNOUNCING!!
v1.3
Services and devices v3.2
GPU-Z v4.6
The whole package is uninstallable via the add/remove panel.
This pack contains:
CPU-Z v1.55
GPU-Z v0.4.6
HD Tune v2.55
HP USB format tool v2.18
HWmonitor v1.15
MemTest v4.0
MSI CleanUp Utility 4.4
Microsoft Config
Smart Driver Backup v2.12
Services and Devices v3.2
User Accounts 2 CPL
WhatInStartup v1.25
Windows Version (Winver)
Size - 2.23 megs MD5Hash = b285a8d3aabb210dcadac9baa2f3ba12
Due to resticitions on my server I had to package the .wa in a rar file...
  • 4 months later...
  • 4 weeks later...
Hello Kels,
I assume this pack is only for x32 bits.
May you be kind preparing the same for x64 bits?
Regards
Edited by coucou
kells hear that does not copy the files to the destination?, apparently does not recognize the value folders, but if you add the record, I had to create the appropriate folder and manually move the files to the right place, there is a special tool to install?
How did you install it?
unzipped the rar and .wa in a folder, Right-click the .inf > install
Ok 2 issues:
This WAS NOT meant to be installed that way!
There is a switchless Win7 CPL pack in the switchless area of this forum...
The way the Win7 toolkit works the inf CANNOT be used to fully install this pack manually.
To see if I kells to install it correctly, you must use this line:
rundll32.exeadvpack.dll,LaunchINFSectioncplbonus.inf,DefaultInstall,3
It is valid for any addon?
Thanks!!!!
Edited by Javo
Aha.
Sorry But I wanted to know what that line.
Thanks Kells!!!
Edited by Javo
  • 3 years later...
