Posted March 11, 201015 yr HomepageOpenExpert adds "Open with" to the context menu of any chosen file type, using any applications you decide. So you can easily open your graphic files with your favorite paint program, or view your HTML files in either Firefox or Internet Explorer, just with a few clicks of the mouse. +++ Main Features +++Adds a user-configurable "Open with" sub-menu to each file. Allows an unlimited number of applications for each file type. Easily add applications for any file types. Import and export of configuration data to copy settings to another system. Very small memory footprint OpenExpert is free for personal use! 2 Sample association extension are provided so that you can add your own to the list of extension..bmp with MS Paint.rar with WinRAROpenExpert_Addon.cabSize: 451.12 Kb (461,944 bytes)MD5: 7E57FC5FC671975ED495E4F63CE38627
