Posted March 14, 201015 yr CAD 2009 Edition for Windows XP v1.6I looked for CAD2009 add-ons on this website, but all I found were Switchless Add-Ons. So I decided to create a true add-on for CAD2009. Using AutoIt, I created a small program that resizes the 1920x1200 picture into whatever resolution is required, then launches the CAD2009 program. This reduced the size of the add-on significantly.HomePage: flawless02.deviantart.com/art/CAD-2009- ... -147097700FileName: Doug_CAD2009_AddOn_v1.2.7zFile Size: 5.10 MB (5,355,613 bytes)MD5 Hash: 813A8E414851762BC5948344228BE434Downloaded [xpcount]Doug_CAD2009_AddOn_v1.1.7z[/xpcount] timesAdd-On Changelog:v1.0 = Initial Releasev1.1 = Replaced 1920x1200.PNG with Background.Bmp and fixed Resize script.UPDATE: CAD 2010 v2.0 has been released! Download links can be found by going here!
March 17, 201015 yr Author Updated CAD2009 add-on to v1.1. Replaced 1920x1200.PNG with Background.BMP and updated resizer script to resize the Background.BMP instead of the other file. Turns out changing the file format saves space as well..... Who would have figured?EDIT: Why did I do this? Well, versions of XPtsp prior to 2.2.0.1 were able to replace the background of my XPtsp-only CAD2009 add-on pretty easily. Version 1.0 of this add-on broke that ability, mandating an update to the CAB/INF combo, hence version 1.1 was released.
March 20, 201015 yr hi dougiefresh! been waiting for this ... when i attempt to dl it though, site says: ERROR: File does not exist! where can i dl the addon? cheers!
March 20, 201015 yr here is the right linkhttp://www.xptsp.com/get.php?url=Downloads/Doug_CAD2009_AddOn_v1.1.7z
March 20, 201015 yr Author Updated first post with corrected link! Thanks, DaRk MaDnEsS and kiki burgh!
December 10, 201311 yr Thanks for updating the links, the add-ons are amazing buddy. We want updates like these to enjoy the work. I am working here in as a cad professional Edited December 10, 201311 yr by janetkissho
