You do know you can make your windows 7 any language you want by installing a lang pack?
It would yield the same result as another with a different lang
If you are looking for something like what it says for "Installed" in certain languages you might not even have to install the lang pack, you could search to see what .mui file the string is stored in and extract the info from the mui with a resource hacker
