Fixit Posted March 17, 2010 Posted March 17, 2010 ---------------------------------------------------------------------------------------------------------------------------------------------------Folder Frenzy v0.2.1 Script By -Fixit----------------------------------------------------------------------------------------------------------------------------------------------------i recently had to create a lot of new folders (about 150 which i really didn't feel like.. lol)and in stead of putting a lot of time in to that i wrote a little program to do it for me this might also be helpful to some.Folder Frenzy v0.2.1Download:(Date: 26-May-'10)MD5:875adf9862ac0604984e1128b68f7828Size:432 KBhope this will save u some time.Regards Fixitchange log:v0.2.1 - 26 May 2010~added checks~added a menubar and aboutv0.2 - 25 Apr 2010~added extra checks~bug fix in the update function~on errors or if a folder already exists an info message will be shown in the main window~counter resets when a different folder name is used in the same session with the list creator.Comment:: Just an .exe nothing will be installed.: u can add a list of names to the large list box via copy past or just by typing them in. (you can also paste a list for e.g. made by Folder Content Lister): a single name like "New folder" per line will result in the folders being created where the program is run from: to specify the location type the full path on each line like: "C:\new folder": "C:\new folder 2":or use the build in list creator for your convenience. u can add up to a 1000 folders at once! Quote
