Posted (edited)
I've read this article in keznews.com and it says that this is a new way to get a genuine key to activate vista.. really genuine?? i dont know.. i haven't tried it yet.
You can download the keygen here: Link Removed
This has been reported to work!......look at the following user comments!!!
zapp2 wrote: This WORKS WORKS WORKS WORKS WORKS WORKS WORKS
2 min a go I ACTIVATED VISTA HOME BASIC..... Shocked Shocked Shocked
Computer User U are the BIG MAN Very Happy Very Happy Very Happy Very Happy Very Happy
CodeCrapper wrote: I GOT A VALID KEY FOR MY VISTA BUSINESS!!!!!! Very Happy Very Happy Very Happy
salmypal wrote: 5 hours and i got 3 legit keys. will leave it on for 2 days and will keep letting everyone know. need one ? i'll give only if your a long time keznews user. Wink
Nice easy to follow instructions thanks guys:
1: download the file slmgr.zip (links below)
2: make a backup of C:\windows\system32\slmgr.vbs (in case the keygen works, replace it back with the original)
3: use slmgr.vbs from the zip-file to replace the one in C:\windows\system32\. If you have problems with permissions, select file...goto properties....take ownership....then change permissions.
4: write down your partial or entire productkey. You can check your key with "magic jellybean" (from our pack)
5: goto Start > Run, type "cmd" and OK. Now type "C:\windows\system32\slmgr.vbs -ipk generate". A process called "wscript.exe" will start and can take quite a lot of CPU resources. It will check aprox. 10000 keys per 30 minutes.
6: now the waiting begins. It can take very very very long before you get some results
7: after some time (hours, days) check your productkey with "magic jellybean" again to see if it has changed
8: if your serial has changed try to activate Vista by going to Start > Run. Now type the command "C:\windows\system32\slmgr.vbs -ato"
DONE!
KEYGEN PROVIDED BY COMPUTER USER!...thanks fokes for your "patience!" Laughing
DISCLAIMER: under no circumstances should anyone sell the key that they generate. I do not support Piracy, this was simply an experiment in which i used to practice my vbscripting. This was just for fun and was a complete accident! sorry for cracking your beautiful operating system BILL GATES
If this works, Please Tell Me.. hehehe... I've checked it and there's no virus...
Edited by ricktendo64
Against Forum Rules
