Posted March 27, 201015 yr change wallpaper in wpi? i want to change the wallpaper of windows post installer[wpi] its great software for silent install. but when i change the wallpaper wallpaper does not change. something like wrong error sign appear on top.. what is it? how to remove? and how to change wallpaper? plz. help me. thnks. image link is here. http://img684.imageshack.us/img684/1162/67781092.png how to set wallpaper? which script i need to modify? plz. help me. thnks... Edited March 27, 201015 yr by Kelsenellenelvian Fixed the GROSS over-use on punctuations.
March 27, 201015 yr OK did you READ the manual?The cross is the sign of the pic not being able to be displayed... What format are you using?Where is the pic?What did you enter in the options section?
March 27, 201015 yr Author ya... i use manuall all is done i make full wpi all software is installed correctly...all is done but the problem is only change wallaper and change theme.... plz help me.... i use wpi setting is here.....[windows setting]http://img532.imageshack.us/img532/6592/1windows.jpg style setting...http://img440.imageshack.us/img440/131/2style.jpg general setting is here...http://img717.imageshack.us/img717/6392/3general.jpg tools setting is here.....http://img715.imageshack.us/img715/8175/4tools.jpg configuration setting here....http://img88.imageshack.us/img88/976/myconfigurationsetting.jpgor other thing is when i change the theme it shows errors like this..... i copied all theme in theme folder of wpi but it shows errors like this.... so wht can i do??????? friends....plz.... rply me.... i m very thnkful to u... plz... help me...how to change wallpaper and how to change theme???????????/ thnks...................... Edited March 27, 201015 yr by dreamboy_shah
March 27, 201015 yr OK NOW STOP WITH THE PUNCTUATION MARKS! IT IS PI$$IN ME OFF!You HAVEN'T read the manual fully it is in chapter 2 how to do this sh!t!See attached pic.(Everthing you want is in the style tab.)Practice some patience and better punctuation in the future!Hint: use a name without spaces and place the pic in the graphics folder.
March 27, 201015 yr Same effin thing. You dl the theme and extract it to the themes dir then select it.ONE MORE WARNING ABOUT THE PUNCTUATION MARKS. Use that amount again and I will ban you!
