dreamboy_shah Posted March 28, 2010 Posted March 28, 2010 when i open wpi in customizing o.s. it shows error like this...........http://img138.imageshack.us/img138/9449/11510041.jpgwht is the reason guys???? a also open autorun it opens command prompt and quick exit.....why do this?????how to solve this error???? other o.s. s autorun and w.p.i. is completly run.... wht is the problem???help me plz... .thnks.................
dreamboy_shah Posted March 29, 2010 Author Posted March 29, 2010 I will not help you anymore.sory sir.... but whts the reason?????????????????
Kelsenellenelvian Posted March 29, 2010 Posted March 29, 2010 All of the extra punctuations (Periods and question marks) I told you to stop using.It seems very rude and demanding.
dreamboy_shah Posted March 29, 2010 Author Posted March 29, 2010 ok.sory sir. again i cant use extra punction like questionmarks etc. again i use simple method. sory sir.
Kelsenellenelvian Posted March 29, 2010 Posted March 29, 2010 OK here is the deal:Goto the home page and download a fresh copy.Then upgrade your current WPI with it.How to upgrade?1.Download and unRAR to a different location.2.From your old WPI folder, copy config.js, useroptions.js, and windowoptions.js from WPIScripts to the new WPIScripts folder.3.Copy your Audio folder from old to new.4.Copy your Install folder from old to new.5.Copy Themes folder from old to new.6.Rename or move your old folder in case something goes wrong.7.Move the new WPI folder to where you want it.THEN update your scripts to point to WPI.exe NOT WPI.hta! We now are using a custom .exe to start wpi and this should fix your problem.
dreamboy_shah Posted March 30, 2010 Author Posted March 30, 2010 ok. thnks sir. so if i want to add wpi in autorun pro. so which file i need to add show the path?which wpi i want to select?http://img444.imageshack.us/img444/3860/69239405.jpgi want to add wpi here. if we click here then open wpi.
ricktendo Posted March 30, 2010 Posted March 30, 2010 This guy is clearly making a warez XP.../closed /warned /suspended
