Posted March 29, 201015 yr here the new Vista drive icon silentlyplease anybody crate the rvm add on with inf .no svpack .just like Kelsenellenelvian vdrive iconVistaDrive.7z Edited May 1, 201014 yr by rebi
March 29, 201015 yr Creating silent switch installers are pretty easy, check out this tutorial (to install this program silently use /S)Also check out SFX Maker http://www.ryanvm.net/forum/viewtopic.php?t=6434
March 29, 201015 yr Author rik i don,t want to install silentlyi want to make like this:Kels_VistaDriveIndicator_addon_v2.2.CAB
March 30, 201015 yr Author rickyou have a habit that one time answer the questionand onother time notplz help me to creat that one
March 30, 201015 yr rik i don,t want to install silentlyi want to make like this:Kels_VistaDriveIndicator_addon_v2.2.CABYou dont need to make addon archive, the rvm integrator will integrate your silent switch installers in the form of a silent .exerickyou have a habit that one time answer the questionand onother time notplz help me to creat that oneAll the info you need to know was posted above, time to learn how to make silent switch installers. Then you wont need to depend on others
March 30, 201015 yr Author You dont need to make addon archive, ( I need it and if you don,t want to never mind i finally creat it myself) the rvm integrator will integrate your silent switch installers in the form of a silent .exe ( i know that but i want craet addon archivers like what i said.)also thanksnevermind
March 30, 201015 yr Author here you are i myself creat it vistadrive Icon 1- new icon 2- clearly icon3- Very Smarthttp://up.iranblog.com/2161/1270025403.rarbut if any body can creat new icon and inf setup for flash and usb it must be better than ..be best for every time ....
March 31, 201015 yr Lier! You did NOT create this!It is the EXACT same as mine.I give you ONE chance to remove yours and retract this addon or I will ban you.
March 31, 201015 yr Author Lier! You did NOT create this! ====>>>> i think you didn,t read carefully ... i change this icon,s dear not creat the softIt is the EXACT same as mine. ====>>>> exactly the same of you but you can see your icon,s and mine it is a lot of different and thank you for you seeing i know you creat a good one , i add some icon,s in it , plz see more my attachment an my dialogi like your work you are the best I give you ONE chance to remove yours and retract this addon or I will ban you ===>>> almost u restricted me , i have some better than older ver and send it for you , what is problem ?i change my dialog ok ?
April 3, 201015 yr I am talking about this one.The icons appear IDENTICAL to mine and the inf is MINE.I see ONE icon different!here you are i myself creat it vistadrive Icon 1- new icon 2- clearly icon3- Very Smarthttp://up.iranblog.com/2161/1270025403.rarbut if any body can creat new icon and inf setup for flash and usb it must be better than ..be best for every time ....
April 4, 201015 yr Author here is the exactly differenthttp://up.iranblog.com/Files/219e39b89a9d4b279381170061dbff30.JPGi know you and your work .i like youre work .i must to say you well done
