OK... This was made to install INF addons without the need to build a new CD... If you look inside a addon and then look at the INF file look for a [DefaultInstall] section that means that this addon can be installed manually example my Flashget addon has a default install section
[DefaultInstall]
CopyFiles =FlashGet.Files,Config.Files,Lang.Files,Skin.Files,Sound.Files
AddReg =FlashGet.Uninstall,Run.AddReg,RunOnce.Execute
ProfileItems=FlashGet.AddShortcut,Uninstall.AddShortcut,QuickLaunch.AddShortcut
RegisterDLLs=FlashGet.DLLs
You don't really need this tool to install the addon btw, here are instructions on how to install a INF addon
- Extract the INF addon
- Right click on the INF file and choose Install (you will get an error, its looking for the i386 folder)
- Browse to the .CAB file with all the addons program files in it
- Hit Open then OK and your INF addon will be installed
That is what this tool does, it simplifies Default INF Install (Hope you understood that)
AddOnInstaller SendTo Style by Nightwolf81
Installs AddOns with [DefaultInstall] Section in the INF.
MD5: 870A5A6EFAD2305E5B0A94E0FC3B742F
Thanks Rick! This looks great!!! I can get much use from this!!!! :thumb_yello:
