science Posted April 15, 2010 Posted April 15, 2010 Hi!I am adding drivers to Win 7 with DISM, but there are a conflict with two audio drivers, Via Vinyl AC'97 Codec Combo and Realtek AC97, so i was told that the only solution was to make the Via Vinyl AC'97 Codec Combo unsigned, for lower ranking, but i dont know how to make a driver unsigned, anybody here that can guide me to the right direction. Quote
ricktendo Posted April 15, 2010 Posted April 15, 2010 Edit the INF file, add a comment or something like; Unsigned Quote
science Posted April 16, 2010 Author Posted April 16, 2010 Edit the INF file, add a comment or something like; UnsignedThank you, i did add that to the .inf, and used /ForceUnsigned option in dism, and now the Realtek driver get installed, thanks again Quote
science Posted April 17, 2010 Author Posted April 17, 2010 What i meant was, that now the Realtek driver get installed instead of the Via Vinyl AC'97 driver, on the integrated Realtek sound-card... Quote
ricktendo Posted April 19, 2010 Posted April 19, 2010 Now that I think about it the best way to make your driver unsigned is to simply delete the .CAT file. Then after you install your OS and the driver is installed successfully you can install the cert which will make your driver signed againThis is better than editing the INF...I have no idea how to install the cert unattendedly but somebody may know Quote
