Posted April 22, 201014 yr Hi everybody!////////////////////////////// REQUEST #1 /////////////////////////////////////////I'm workin' on Nero 8.3.20.0 Lite/Micro true addon (english/french). One thing missing : i plan to check reg entries about nero previous versions(v7/v8).If ONE of these reg entries is found, a message will prompt user : "A previous version of Nero has been founded on your system. Please uninstall it before continuing.". This will abort addon installation.I'm tryin' to use CustomDestination directive to check Windows registry. But i'm little bit confused about its using.[install.Nero8Lite]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %01%\Nero8L.inf,Install"[install]BeginPrompt = ...CustomDestination = Nero.PreviousVersions.DetectedRunPreSetupCommands = Create.i386:1,MSVC++2005.Check:1,Nero8PreInstall.Check:1[Nero.PreviousVersions.Detected]49000=Nero7Lite.Check,22[Nero7Lite.Check]"HKLM","SOFTWARE\Nero\Installation\Families\Nero 7","","%Nero7Lite_FOUNDED%.",""[strings]Nero7Lite_FOUNDED="A previous version of Nero has been founded on your system. Please uninstall it before continuing"Durant my tests, this above prompt message is shown, even there's no regentries for NERO.////////////////////////////// REQUEST #2 /////////////////////////////////////////I'm also workin' on an addon for Nero 9.4.26.0b. And i'm lookink for how to check if .NET Framework 3.0 (Registry check) is installed or not.PLEASE YOUR HELP, LINKS & ADVICES WILL VERY APPRECIATED. THANX Edited April 22, 201014 yr by Ken@fri
April 22, 201014 yr This only works the other way around...if the program/reg-entry is NOT installed it will fail, only if it finds the registry entry will it installYes your second request is what this is used for, to check for a registry entry...if it finds .net 3.0 reg entry you specify ONLY then will it proceed
April 22, 201014 yr something likeRunpresetupcommands =Close.IDM:1[Close.IDM]"CMD /Q /C taskkill /f /t /im ""idman.exe"""
April 23, 201014 yr Thanks Dark.It's correctly :[install]CustomDestination=RessourceHacker.Detected[RessourceHacker.Detected]49000=RessourceHacker.Check,1[RessourceHacker.Check]"HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111194}","","% %.","" RessourceHacker_FOUNDED[strings]RessourceHacker_FOUNDED = "Une version Ressource Hacker a
April 23, 201014 yr Author :welcome: :welcome: :welcome: @ ricktendo64, Alpha_95, DaRk MaDnEsSThanx 4 ur replies & contributions :thumbsup_anim: .I finally choose to use RunPreSetupCommands to solve my problem.Bye ! Edited April 23, 201014 yr by Ken@fri
April 23, 201014 yr Author HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111110}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111111}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111112}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111113}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111114}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111115}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111116}HKCR,"CLSID\{D14ED2E1-C75B-443c-BD7C-111111111117}Hello Alpha_95 !Dans le mod
April 26, 201014 yr Author Salut Alpha_95 :welcome: !Les entrées de ton soft pour affichage dans le Panneau de configuration peuvent être SIMPLEMENT supprimées AVANT L'INSTALL (avant réécriture éventuelle) :[DefaultInstall]RegisterDlls = Install.TON_APPLI[install.TON_APPLI]11,,rundll32.exe,,,"advpack.dll,LaunchINFSection %01%\TON_FICHIER_INF.inf,Install"[install]BeginPrompt = BeginInsPromptRunPreSetupCommands = Create.i386:1,PreInstall.Check:1CopyFiles = @TON_FICHIER_INF.inf,...AddReg = CPL.Entries.AddRegRunPostSetupCommands = Delete.i386[PreInstall.Check]DelReg = CPL.Entries.DelReg[CPL.Entries.DelReg]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\D14ED2E1-C75B-443c-BD7C-111111111294"[CPL.Entries.AddReg]HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\D14ED2E1-C75B-443c-BD7C-111111111294"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\D14ED2E1-C75B-443c-BD7C-111111111294",,,"Add My Prog to The Control Panel"Voici, par exemple, comment j'ajoute/supprime une icône pour Nero ControlCenter dans le Panneau de config (le GUID a été généré à l'aide du soft M$ cité + bas) :[NeroControlCenter.CPL]HKCR,"CLSID\{28E478E3-EC15-4531-9BF2-64603C35AE7A}"HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{28E478E3-EC15-4531-9BF2-64603C35AE7A}"HKCR,"CLSID\{28E478E3-EC15-4531-9BF2-64603C35AE7A}",,,"Nero ControlCenter"HKCR,"CLSID\{28E478E3-EC15-4531-9BF2-64603C35AE7A}","InfoTip",,"Maintenez Nero à jour !"HKCR,"CLSID\{28E478E3-EC15-4531-9BF2-64603C35AE7A}\DefaultIcon",,,"%16427%\%Nero_Web%\SetupX.exe"HKCR,"CLSID\{28E478E3-EC15-4531-9BF2-64603C35AE7A}\Shell\Open\command",,,"""%16427%\%Nero_Web%\SetupX.exe"" MODE=""update"""HKLM,"SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{28E478E3-EC15-4531-9BF2-64603C35AE7A}",,,"Ajoute Nero ControlCenter au Panneau de configuration."Si t'as d'autres questions ou souhaites approfondir, RDV sur le sous-forum FR de wincert. Créés-y un nouveau topic et fournis moi le lien par MP, ou on se retrouve sur le site de Moebius ?//////////////////////////////////////////////////////////////////////////////////////////////////////////I use Microsoft Exchange Server GUID Generator (GUIDGen) to generate GUID's.If u've more questions, please let's continue this discussion in french on Wincert's French sub-forum or on Moebius' site. OK? Thanx :thumbsup_anim: . Edited April 26, 201014 yr by Ken@fri
May 7, 201014 yr not sure but what about testing with the cmdsomething like ""%16422%\My_Prog\uninst.exe" /S"
