[Addon] Nero Suite 8 Lite (ENU/FRA)
Ken@fri
NeroBR8_Banner.pngNero Burning ROM 8.3.20.0
Publisher : Nero AG
License : Trial
Version : 8.3.20.0
OS : 2000/XP/Vista
Language(s) : English/French
CRC-32 : df8b0ded
MD4 : c421b55c8f22d21191d338c7787f2ca3
MD5 : d1ef2d3b47663a750f7c77f3922b52b4
SHA-1 : b8c2b0e36848895d5ef73426f2a792c4dcc70cd9
Followings Apps are included in Nero 8 Micro (+ Help Files) :
  • Nero Burning Rom
  • Nero Express
Installed Components:
  • Nero Audio Plugins
  • Nero VideoCD Support
Custom AddIns:
  • Nero InfoTool
  • Nero ControlCenter added to Control Panel
Included in Nero 8 Lite:
  • Nero Burning Rom
  • Nero Express
  • Nero Cover Designer
  • Nero Wave Editor
  • Nero Toolkit (BurnRights, DiscSpeed, DriveSpeed, InfoTool)
Files Association : .nab, .nhf, .nhv, .nmd, .nr3, .nr4, .nra, .nrb, .nrc, .nrd, .nre, .nrg, .nrh, .nri, .nrj, .nrm, .nrs, .nru, .nrv, .nrw, .nsd
NOTE :
  • Based on/inspired by Nero 8.3.2.1 Micro True Addon by Preputium64
  • Supported Languages : english & french
  • it's installable/uninstallable with Add/Remove Windows Components function.
    Nero 8 Lite's Sub-components: Nero Burning ROM , Nero CoverDesigner, Nero WaveEditor
    Nero 8 ToolKit's Sub-components : Nero BurnRights , Nero DiscSpeed, Nero DriveSpeed, Nero InfoTool
    The deletion of Nero Suite 8 Lite means deletion of ALL others components
    The deletion of Nero Burning ROM means deletion of ALL others components
    Addon available here coming from Nero 8.3.20.0 Lite (build 1.20.1.1) & downloadable from updatepack.nl
  • NONE serial given .
    This is how to register Nero :
    • extract (with 7Zip, WinRAR...) addon
    • Open Nero8L.inf file, go to [strings] section & give infos below:
    ;--------------------- REGISTRATION INFOS ---------------------------------
    YOUR_NAME =""
    YOUR_COMPANY =""
    YOUR_SERIAL =""
    [*]After that, re-compress archive or install...Voil
Link to comment
Share on other sites
