rebi Posted April 30, 2010 Posted April 30, 2010 1. I integrated in win xp sp3 in the desktop i have this shortcut how can i solved ? i don't want have in my desktop after install windows2. my default language is Persian how can i change it to english Quote
ricktendo Posted April 30, 2010 Posted April 30, 2010 Whose updatepack are you using?That shortcut is put there by KB976002-v5 Quote
rebi Posted May 1, 2010 Author Posted May 1, 2010 YumeYao_IE8_Addon_Nosetuperr_ENU_1_3_5no errors found in setuperr.log just create this shortcut Quote
ricktendo Posted May 1, 2010 Posted May 1, 2010 You still have not answered the question, whose UpdatePack do you use?Go complain to them, they added KB976002-v5 thats why you get this shortcut, has nothing to do with IE addon its the updatepackMore info Quote
rebi Posted May 1, 2010 Author Posted May 1, 2010 i use this one for ie8 : YumeYao_IE8_Addon_Nosetuperr_ENU_1_3_5and this one for sp3 : XPSP3_QFE_UpdatePack_1.2.2_20100325_2 Quote
Kelsenellenelvian Posted May 1, 2010 Posted May 1, 2010 I edited your title!Please do not yell (TYPE ALL IN CAPITOLS) when using the forum... Quote
user_hidden Posted May 1, 2010 Posted May 1, 2010 i use this one for ie8 : YumeYao_IE8_Addon_Nosetuperr_ENU_1_3_5and this one for sp3 : XPSP3_QFE_UpdatePack_1.2.2_20100325_2both the update pack and addon you are using are OLD !use the newer versions. Quote
rebi Posted May 1, 2010 Author Posted May 1, 2010 thank you but if you say both of them is old ok please give me the newer one , the direct link and so again thanks Quote
5eraph Posted May 1, 2010 Posted May 1, 2010 It's not polite to post direct links to other people's files without permission. But I will give you links to their respective release threads:XPSP3_QFE_UpdatePack for Windows XP Post-SP3 by user_hiddenInternet Explorer 8 for XP/2k3 by YumeYao Quote
rebi Posted May 2, 2010 Author Posted May 2, 2010 i use your update pack i see this error's what is that and how can i solved iti use : XPSP3_QFE_UpdatePack for Windows XP Post-SP3 by user_hiddenInternet Explorer 8 for XP/2k3 by YumeYaohere the pic of error Quote
5eraph Posted May 2, 2010 Posted May 2, 2010 That is normal with YumeYao's Clean style IE8 addon. If you want no errors in SetupErr.log then use the No Setuperr style IE8 addon. Quote
rebi Posted May 3, 2010 Author Posted May 3, 2010 thanks so muchi use it again without any error Quote
