Posted May 5, 201014 yr i change boot screen of windows xp sp3 and i have this pic for chksdk in run and i will see in this picture .how can i Chang the color and this word . vista boot screeni use that one for Chang my boot screen :WinXP_Pro_Vista BootScreen Blue (5857)_addon Edited May 5, 201014 yr by rebi
January 31, 201114 yr Author hiso long to meet a lot of good friend hereagain i am here dears i see those picture when i chekdsk and restart for cheking disk wich text or file mast be edit ?
February 21, 201114 yr Author hiso long to meet a lot of good friend hereagain i am here dears i see those picture when i checked and restart for checking disk which text or file mast be edit ?1- Extract the driver.cab or sp3.cab 2- find 4 file with this names : 1) ntkrnlmp.exe 2) ntkrnlpa.exe 3) ntkrpamp.exe 4) ntoskrnl.exe3- with resource hacker open those files .4- change the bitmap of picture in photo shop . for seeing the picture you must use this attached file 5- after changing files . replaced with original one in resource hacker 6- after saving replace those 4 file in sp3.cab or driver.cab 7- repack or archive it 8- be smarte like me16 Bit.7z
February 21, 201114 yr Author like this files 1- Extract the driver.cab or sp3.cab 2- find 4 file with this names : 1) ntkrnlmp.exe 2) ntkrnlpa.exe 3) ntkrpamp.exe 4) ntoskrnl.exe3- with resource hacker open those files .4- change the bitmap of picture in photo shop . for seeing the picture you must use this attached file 5- after changing files . replaced with original one in resource hacker 6- after saving replace those 4 file in sp3.cab or driver.cab 7- repack or archive it 8- be smarte like me6.bmp14.bmp
