Alien Arena
Description
Do you like fast paced deathmatch? How about rich, colorful, arcadelike atmospheres? How about...retro Sci Fi?
Then you're going to love what Alien Arena has in store for you! This game combines some of the very best
aspects of such games as Quake III and Unreal Tournament and wraps them up with a retro alien theme, while
adding tons of original ideas to make the game quite unique.
Alien Arena is a fast paced, furious frag fest with arenas ranging from the small, to the massive. With a large
built-in player base, it's never hard to find a good match going on, at any hour of the day. The community is
friendly, as well as prolific. Dozens of maps, models, and various accessories have been created by community
members to add on to the game experience. The CRX engine that powers Alien Arena has received very signifigant
upgrades in recent releases, resulting not only in stunning new visuals, but vastly increased performance as well
Changelog
What's New
Major 7.53 features:
1. Extended use of VBO for signifigant performance increases on high settings.
2. A number of bot AI changes to improve navigation, combat and more human like behavior.
3. Added a number of video resolutions.
4. "Dm Lights" server option.
5. Menu changes to make things behave more consistently and intuitively.
6. When entering join server menu, servers only refreshed on first entry, unless refresh button is pressed.
7. Entity def files to allow maps to have multiple game types and configurations.
8. Chaingun behavior smoothed out.
9. Grass/vegetation rendering visually improved, and optimized.
10. CTF scoring improvements.
11. Smarter precaching.
12. Speed hack detection improvements.
13. Fixed account bugs.
14. Optimizations for IQM and MD2 rendering.
15. Stats math refactoring.
16. New maps - TCA-Invasion, CTF-Zion2k9
17. New violator sounds, skin, and effects.
18. Added "ultra" skill level to single player mode.
19. Added sun object control to scripts.
Important SVN commits:
Revision: 2701
Author: max
Date: 7:27:53 PM, Monday, December 19, 2011
Message:
FOR TESTING: Add "hang" command to simulate hangs.
Can be used to study the effect of client or server-side hangs on the netcode.
Currently Unix-only. Only useful for developers.
Revision: 2700
Author: irritant
Date: 5:07:38 PM, Monday, December 19, 2011
Message:
Changed some compiler optimization settings, this appeared to be causing memory issues.
Revision: 2697
Author: irritant
Date: 11:54:13 AM, Saturday, December 17, 2011
Message:
Removed gl_lockarray calls when using vbo on meshes. Seems to have fixed any crashing issues.
Revision: 2695
Author: strat
Date: 1:23:21 PM, Wednesday, December 14, 2011
Message:
Fixed bot fuzzy aim so skill and accuracy config differences make a difference.
Revision: 2694
Author: irritant
Date: 6:47:12 PM, Tuesday, December 13, 2011
Message:
Added "nosun" field in .fog files.
Revision: 2693
Author: irritant
Date: 12:52:31 AM, Tuesday, December 13, 2011
Message:
Added ultra skill level to single player menu.
Working shadow vbo's using dynamic vbo(slower, so commented out for now).
Revision: 2690
Author: irritant
Date: 1:06:35 AM, Saturday, December 10, 2011
Message:
Large number of bot improvements with navigation, accuracy, and AI.
Removed unused bot code(the stuff where bots could drop nodes and build links, i.e. learn the map). This was never used(and potentially ruined existing paths).
CTF nodes added to code(but ifdef'd out, as it's not quite working yet). Test using ctf-zion2k9(it has the base node paths added).
Revision: 2687
Author: irritant
Date: 1:15:48 AM, Wednesday, December 07, 2011
Message:
Bots no longer fire back when attacked by their own teammates.
Revision: 2686
Author: irritant
Date: 1:01:07 AM, Wednesday, December 07, 2011
Message:
Improvements to movement AI.
Revision: 2684
Author: irritant
Date: 11:12:28 PM, Tuesday, December 06, 2011
Message:
Added some better strafejump checking for level 3 bots.
Revision: 2683
Author: strat
Date: 7:44:15 PM, Tuesday, December 06, 2011
Message:
Update Autotools build for newer .m4 macros.
Update version to 7.53.
First cut on README updates for 7.53.
Update game_data.am with ctf-zion2k9.nod.
Revision: 2682
Author: irritant
Date: 4:14:38 PM, Tuesday, December 06, 2011
Message:
Fix vid res bugs, add 1366x768, 1280x1024.
Revision: 2681
Author: irritant
Date: 1:16:24 AM, Tuesday, December 06, 2011
Message:
Violator alt-fire uses different effect.
Revision: 2680
Author: irritant
Date: 12:33:34 AM, Tuesday, December 06, 2011
Message:
Ctf-Zion2k9 final version.
Ctf-Zion2k9 bot path.
Added 1920x1080 screen res to menu.
Added VBO to vid menu(on by default).
sv_enforcetime set to 0 by default until further tested and bugs fixed.
Statsgen reads ftp account info from file.
Updated rev to 7.53
Revision: 2679
Author: irritant
Date: 12:35:34 AM, Monday, December 05, 2011
Message:
Clear all vbo ID's on map reloads.
Revision: 2677
Author: strat
Date: 10:11:57 PM, Sunday, December 04, 2011
Message:
Change a packet rate timing variable.
Revision: 2676
Author: strat
Date: 3:32:13 AM, Sunday, December 04, 2011
Message:
Major update to statsgen with improved data collection and error handling.
Revision: 2674
Author: irritant
Date: 12:30:58 PM, Friday, December 02, 2011
Message:
Menu items now consistent with highlighting.
Rethink - vbo now on by default for any card that can use it.
Revision: 2672
Author: irritant
Date: 12:35:14 AM, Friday, December 02, 2011
Message:
Level 0 bots should not crouch.
Revision: 2671
Author: irritant
Date: 12:19:34 AM, Friday, December 02, 2011
Message:
Revision: 2670
Author: irritant
Date: 11:32:33 PM, Thursday, December 01, 2011
Message:
Fixed some bot configs, changed dm-goregrinder to have easy bots.
Revision: 2666
Author: strat
Date: 4:57:22 PM, Sunday, November 27, 2011
Message:
Modify error handling and enhance error messages for clc_move command.
Remove redundant and unnecessary traces in SV_Multicast.
Fix misplaced debug print statement in CL_Frame.
Revision: 2664
Author: max
Date: 12:59:57 AM, Sunday, November 27, 2011
Message:
speed cheat code:
Add code to reset speed cheat data collection whenever the server hangs.
TODO: only reset the data when the hang occurs on the boundary of the 12-
second data-collection cycle. I suspect the current code might almost
disable the speed-cheat detection on very overloaded servers. However, this
should fix false positives at any rate.
Revision: 2662
Author: irritant
Date: 12:30:20 AM, Thursday, November 24, 2011
Message:
Max fps, pps, default set to 60.
Cleanup of some vbo stuff.
Revision: 2661
Author: strat
Date: 1:00:47 AM, Wednesday, November 23, 2011
Message:
Update for autoconf macro archive changes. (Build requires 'make clean' and './configure')
Update game_data.am.
Revision: 2658
Author: irritant
Date: 4:46:29 PM, Tuesday, November 22, 2011
Message:
Update to violator skin.
Revision: 2655
Author: strat
Date: 2:26:14 AM, Tuesday, November 22, 2011
Message:
Update game-data.am for tca-invasion and ctf-zion2k9.
Add nul-termination to entity string when loaded from .entdef file.
Revision: 2654
Author: max
Date: 1:31:57 AM, Tuesday, November 22, 2011
Message:
Fix minor bug where g_dm_lights wouldn't get archived if game code didn't run.
Revision: 2650
Author: irritant
Date: 12:35:54 AM, Tuesday, November 22, 2011
Message:
Added ctf-zion2k9 courtesy of Rigel.
Revision: 2648
Author: irritant
Date: 12:02:54 AM, Tuesday, November 22, 2011
Message:
Fixed net error in new team light code.
Revision: 2647
Author: max
Date: 10:49:41 PM, Monday, November 21, 2011
Message:
Server: display visibility lights for DM games when g_dm_lights is 1.
Client: display those lights in green (older clients will display them blue.)
Revision: 2646
Author: max
Date: 12:49:53 AM, Monday, November 21, 2011
Message:
Initial version of tca-invasion.
Uses the same BSP as ctf-invasion, but with a separate entdef file.
Revision: 2645
Author: strat
Date: 1:51:21 PM, Sunday, November 20, 2011
Message:
Fix frag rate and total time in in-game player stats to be consistent with statsgen.
Revision: 2644
Author: irritant
Date: 10:36:50 AM, Sunday, November 20, 2011
Message:
Fixed bug with name storage and stripped chars.
Revision: 2643
Author: irritant
Date: 11:51:59 PM, Friday, November 18, 2011
Message:
Cleaned up shadow and vbo code.
Revision: 2642
Author: max
Date: 9:47:36 PM, Thursday, November 17, 2011
Message:
Partially fix the false positives for the speed cheat code.
I found that this was happening when the *server* hangs, not when the *client*
hangs, as I previously thought. This explains why my code to simulate hangs
was only duplicating the issue in listen servers. I am now using
Sys_Milliseconds instead of svs.realtime, which has partly cured that problem.
However, a very long server-side hang can still cause false positives if it
falls on the "cusp" between one 12-second data-gathering period and another. I
plan on fixing that by adding a mechanism to "forgive" anything detected
whenever this happens. Not ideal, but hey, what can ya do?
Revision: 2639
Author: irritant
Date: 11:57:50 AM, Tuesday, November 15, 2011
Message:
Some IQM optimization. More to come.
Revision: 2638
Author: strat
Date: 3:16:36 AM, Tuesday, November 15, 2011
Message:
Read Account Server 'validated' file once per loop.
Start decaying score after 2 weeks instead of 4.
Revision: 2636
Author: irritant
Date: 6:17:08 PM, Monday, November 14, 2011
Message:
Fixed bug with password cvar.
Revision: 2634
Author: max
Date: 5:45:48 PM, Sunday, November 13, 2011
Message:
Fix one of two suspected bugs with sv_enforcetime.
This is the more obvious problem, where players are always kicked on their
second map after a long enough time.
Revision: 2633
Author: strat
Date: 2:39:12 AM, Thursday, November 10, 2011
Message:
Add timeouts to stats database and latest version cURL reads to prevent hang on Join Server menu.
Revision: 2631
Author: max
Date: 9:04:43 PM, Sunday, November 06, 2011
Message:
sv_enforcetime now has a margin of error, but it also now kicks speed cheaters.
It's also now on by default.
Revision: 2630
Author: max
Date: 8:25:04 PM, Sunday, November 06, 2011
Message:
Don't precache everything on local games where maxclients is 0 or 1.
This is so I don't have to wait for ages just so I can test some code.
Revision: 2629
Author: strat
Date: 7:55:39 PM, Tuesday, November 01, 2011
Message:
Add Rigel's CTF scoring improvements: return flag was 2, now 5 points; frag enemy flag carrier was 1, now 5 points.
Fix screenshots for 1366 video width.
Revision: 2628
Author: irritant
Date: 5:58:26 PM, Tuesday, November 01, 2011
Message:
Fix vegetation draw order.
Revision: 2627
Author: irritant
Date: 4:40:01 PM, Tuesday, November 01, 2011
Message:
Some more efficient grass rendering.
Revision: 2626
Author: max
Date: 10:30:27 PM, Saturday, October 29, 2011
Message:
Remove code that calculates "move" and adds it to every vertex's position.
Experimental observation indicates that IQM_DrawFrame is never called on
an entity where oldorigin != origin, so the code was useless anyway. This
commit unbreaks cl_testentities. It also probably improves fps very slightly,
but not enough for me to notice.
Revision: 2625
Author: irritant
Date: 7:42:12 PM, Saturday, October 29, 2011
Message:
Much improved grass rendering.
Revision: 2624
Author: max
Date: 1:07:48 AM, Friday, October 28, 2011
Message:
Factor out a few if-statements from the IQM VArray-building loops.
Revision: 2622
Author: irritant
Date: 12:31:57 AM, Wednesday, October 26, 2011
Message:
1. Mesh vbo now fully working. I've left r_test as a toggle for testing performance. (must also be used in conjuction with gl_usevbo).
2. A number of debugging statements in AccountServ.
Revision: 2621
Author: irritant
Date: 12:48:54 AM, Saturday, October 22, 2011
Message:
Mostly working mesh vbo. There is still a problem with tangents. Use gl_usevbo 1 and r_test 1 to test. r_test enables and disables the mesh portion of the code.
Fixed string bugs with accountserver.
Revision: 2620
Author: max
Date: 3:36:54 PM, Wednesday, October 19, 2011
Message:
Fix irritating chaingun behavior when letting go of the primary-attack button.
The chaingun will no longer waste ammo going through the whole firing
animation even when the fire button is no longer held.
Revision: 2618
Author: max
Date: 6:49:36 PM, Monday, October 10, 2011
Message:
Script to generate entdef files (dumps of the entity data) from a source .map.
The R1Q2 project has a C program to generate dumps from a .bsp file, which I
may also commit later (for maps where the source is lost.)
Revision: 2617
Author: max
Date: 6:40:49 PM, Monday, October 10, 2011
Message:
System for breaking various hunks out of BSP files. Only entity data for now.
This is very slightly different to the patch I initially submitted. I will
make a forum post on it and possibly work with Strat to get it documented in
the "devref" document.
Revision: 2616
Author: max
Date: 1:16:21 AM, Thursday, September 29, 2011
Message:
Get rid of fixed FOV from the server-side and menu code.
TODO: Ignore fixed FOV on the client side if a legacy server has it enabled.
Revision: 2615
Author: max
Date: 1:09:17 AM, Thursday, September 29, 2011
Message:
target_speaker rejects any file with "music" in its name.
This is a fix for legacy maps.
Revision: 2614
Author: max
Date: 1:04:07 AM, Thursday, September 29, 2011
Message:
On Unix, ungrab the mouse during demo playback.
The IN_Frame function for Win32 is slightly different, and I can't test it, so
I won't risk messing with it.
Revision: 2613
Author: max
Date: 12:56:57 AM, Thursday, September 29, 2011
Message:
Haste does nothing unless forward key is held.
Revision: 2612
Author: irritant
Date: 12:36:34 AM, Thursday, September 29, 2011
Message:
Added (re-added) mesh vbo code.
Extended stats decay time to 1 month instead of 1 week, which seemed a bit too fast.
Version: 7.53
Addon Release Date: May 23, 2012
Shortcut created in: Games Folder
Uninstallable: Yes
Credit: *Reaper*
x64
158228d360ac251fcec90a6287146db069513dfeae9006ebc17e2c792d33fc876g.jpg Part 1
158228d360ac251fcec90a6287146db069513dfeae9006ebc17e2c792d33fc876g.jpg Part 2
158228d360ac251fcec90a6287146db069513dfeae9006ebc17e2c792d33fc876g.jpg Part 3
158228d360ac251fcec90a6287146db069513dfeae9006ebc17e2c792d33fc876g.jpg Part 4
96629a48f1e9fce1b831bb585aa9f0f9321d044d2b0fac0fb6048139191a96ed6g.jpg 318 MB
f02bb548e55ad21347822d6b1625b8f5a021938e2b63161f107e9cf54145c4096g.jpg 1baf6ff6c3ca9fa7654d82c8ef335c86
x86
f02bb548e55ad21347822d6b1625b8f5a021938e2b63161f107e9cf54145c4096g.jpg 861c2879f63ff917eaadb53e91c23a38
ENJOY!
Edited by *Reaper*
  • 1 year later...
  • 10 months later...
