[HELP] Shortcut creation problem
First of all a BIG thanks to this forum for the great information provided on helping
me to learn the inf creation process. A special thanks to Ricktendo64 for his gift
of sharing that knowledge.
I am having one problem I have not been able to find a solution for - the problem of
creating a shortcut for a file name or folder that contains spaces. I realize that
there are 2 obvious workarounds (using the 8.3 file name or renaming the file),
however neither of those options will work for me in all cases. For one, many people
are turning off 8.3 file name creation (it's one of the recommended tweaks for SSD
drives) and renaming the file often leads to other problems.
I have tried using string replacement and playing with the quotation marks but none
seems to work, especially the example below. Any help or suggestions would be
greatly appreciated.
[W7MasterCP.AddShortcut]
Name =Master Control Panel,0x00000008,11
CmdLine =16422,%InstallDir%,%MCPL%
SubDir =%SysUtilDir%
WorkingDir =16422,%InstallDir%
InfoTip =%MasterCP_Tip%
[W7MasterCP.DelShortcut]
Name =Master Control Panel,0x0000000A,11
[Strings]
InstallDir ="ControlPanel Extender"
SysUtilDir ="System Utilities"
MCPL ="Master Control Panel.{ED7BA470-8E54-465E-825C-99712043E01C}"
MasterCP_Tip ="Provides access to 100's of Windows settings and functions all in one place."
Edited by Uncle_Gadget
You gotta love it! After days of searching for a solution and
trying everything I could think of, I discovered a solution less
than 10 minutes after leaving the question above.
The code snippet below provides the answer for those that may be
interested. Apparently the 'space' problem is only present in
the file name field. By moving the file name to the directory
section and placing double quotes for the file name, the system
is 'fooled' into a solution.
Thanks again, everyone, for the inspiration provided in this forum.
CmdLine =16422,%InstallDir%\%MCPL%,""
[Strings]
  • 8 months later...
HA! Neet trick
Kinda reminds me of the trick to make shortcuts to folders
Gotta love it! 8 months later and I'm back looking for.... you
guessed it - How do you make a shortcut to a folder? Apparently
Windows 7 is a bit more fussy than XP.
If you dont specify a IconPath and IconIndex (IconIndex is optional, only if you dont use the very first icon) the shortcut does not work, check out my DP BASE addon, I install it on Windows 7 and it works fine
More here
I actually had tried this method with no success. I then
discovered why it wasn't working - the folder has to exist
PRIOR to the creation of the shortcut or it won't work in
Windows 7. Once that was completed all worked as expected.
Thanks, again, Rick for your assistance!
