FoxitReader 5.4.5.124
Completely customized FoxitReader5.4.5.124, Best Reader for Everyday Use.
OS:Windows Xp,Windows7,Win8 - x86 & X64
Updated on =20130303
This Addons is created By INNO setup v 5.5.3This standalone addon contain*Plugins files and OnDemandCM files*Skins*Removed ASK TOOL BAR, no browser hack to Ask.com*Removed Foxit Search Bar*Removed eBay.ico
 Issue Fixes in Foxit Reader 5.4.3======================================================================================================================Fixed a security issue where the insecure application loading libraries could be exploited to attack the application. What's New in Foxit Reader 5.4======================================================================================================================New Features:1.Supports opening PDF files on Microsoft SharePoint Server and allowing users to seamlessly check out and check in PDF files within Foxit Reader.2.Allows users to easily send, sign and save PDF documents and forms using DocuSign, the industry's most widely used eSignature solution.Issue Fixes:1.Fixed an issue where Foxit Reader may call and run malicious code in the Dynamic Link Library (DLL) file.2.Fixed an issue where the application cannot remember the last print paper size setting.3.Fixed an issue where certain digital signatures cannot be verified by Foxit Reader.
  File: FoxitReader545.0124_enu.exe   CRC-32: 8bab652d   MD4: d6ba1fde28ff08590e98d6151b90c8c6   MD5: 5c3dd7665f2f03129f3e1aa932635615Size:-11.9 MB (12,525,568 bytes)
DownLoad Link:
http://www.mediafire.com/?wyrtwy94jk76ytn
Edited by J.S.Prasad
  • Replies 64
  • Views 30.1k
Addon FoxitReader_4.00.0619 SVCPACK Addon
File: Addon FoxitReader_4.00.0619.7z
MD5: d72c2d7f833d13ce38679bba1108dde5
Foxit Link:http://www.foxitsoftware.com/downloads/index.php
Download link 2:
http://www.esnips.com/doc/ec1dd8fa-48ec-44b5-a142-a3d1df8167eb/Addon-FoxitReader_4.00.0619
Updated
Hi J.S.Prasad
Could you add file association to pdf and there are 2 similar program entry in add/remove panel. Possible to remove 1 out?
Regards
Sorry sir
Pl add a new line in
[Run]
Filename: {app}\Foxit Reader.exe; Parameters: Register; StatusMsg: {cm:AssocingFileExtension,Foxit FDF Document,.pdf}; Tasks: fileassoc
and add a new section with a line after [icons]
[Tasks]
Name: fileassoc; Description: {cm:AssocFileExtension,Foxit FDF Document,.pdf}
And compile the script again till I Update it
Sorry sir
[Run]
[Tasks]
Thanks
FoxitReader_4.00.0619 SVCPACK Addon with pdf file association
CRC-32: 24dc142d
MD4: 66e7974e0a9e3f1eef8aff2bed28d389
MD5: f221a36c8af619f23d0e373f0627ec17
SHA-1: 85e0f6f3b55d7aca26b6014a2333e1fd5aa18094
Link: -
http://www.mediafire.com/download.php?3vzjwmdwmtn
CRC-32: 24dc142d
Link: -
Still have 2 entries in Add/Remove panel. One is valid, one is invalid. BTW, Foxit reader is launch during installation and did not close by itself. Also during uninstall, desktop shortcut is not removed.
Could you remove the desktop shortcut or tell me how to remove it (if there is a switch to it) during installation?
Regards
Please again uninstall it from start menu it should remove desktop short cut, Double entry only may exist by registry section
So pl put ; before these lines or remove them and compile again.
[Registry]
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: DisplayName; ValueType: String; ValueData: Foxit Reader
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: Publisher; ValueType: String; ValueData: Foxit Software Company
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: DisplayVersion; ValueType: String; ValueData: 4.0.0.619
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: EstimatedSize; ValueType: Dword; ValueData: $28CE
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: DisplayIcon; ValueType: String; ValueData: C:\Program Files\Foxit Software\Foxit Reader\Foxit Reader.exe
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: HelpLink; ValueType: String; ValueData: www.foxitsoftware.com/?Language=en
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: UninstallString; ValueType: String; ValueData: C:\Program Files\Foxit Software\Foxit Reader\Uninstall.exe
;Root: HKLM; Subkey: SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Foxit Reader; ValueName: UninstallPath; ValueType: String; ValueData: C:\Program Files\Foxit Software\Foxit Reader\Uninstall.exe
Desktop Shortcut have no issue that OK.U pl remove once manually and check again
To remove it not to appear in desktop put;in [icons]
;Name: {userdesktop}\Foxit Reader; Filename: {app}\Foxit Reader.exe; WorkingDir: {app}
The code in [Run]
Open the foxit reader during installation that should close manually.
Best Regards
Mr ravirajpoot Here is new ziddu link for You with MD5 Hash.
This addon has revised registry keys no desktop Icon.
MD4: 1c27ab945127cbdc1ce4f3d156a54651
MD5: 55eb306ea8595e5514794e1990fa26db
Link:
http://www.ziddu.com/downloadlink/10617571/AddonFoxitReader_4.00.0619.7z
For switchless installer just extract the addon and run FoxitReader4_enu.exe
in SVCPACK folder.
Thank you
This Addons is created By INNO setup v 5.3.10
Then 7zip switchless Installer is created.
This svcpack addon contain plugins files and OnDemandCM files
Simply unzip for Silent installer.........
Very usefull.
Thanks
if this were to be an Addon, I would suppress the installation so it doesn't show during setup if one integrates it on a new CD.
Is this possible please?
thank you
These command were added to make association with pdf files as per requisite of Mr. Geej.
Now to make it completely silent both can by pass putting ; before
[Run]
;Filename: {app}\Foxit Reader.exe; Parameters: Register; StatusMsg: {cm:AssocingFileExtension,Foxit FDF Document,.pdf}; Tasks: fileassoc
and
[Tasks]
;Name: fileassoc; Description: {cm:AssocFileExtension,Foxit FDF Document,.pdf}
But to make association after setup windows.
Open foxit reader - >select a pdf file to open
and it will make association again with pdf files.
Thanks a lot.
Foxit Reader 4.1.1.0805 is released :icon_cool:
Hi, @J.S.Prasad
Can u make update 4.1.1.0805 this properties pls?
1- Make Silent Association with pdf files
2- Complete full silent
3- "Don't put to desktop foxit pdf shortcut" (I don't see foxit pdf shortcut anywhere)
Thank u very much...
Edited by oguz
