We wanted a simple way to customize our complete Se7en OS, so we created 7tsp.
The patcher will back up the original (current) system files, and patch your Windows 7 with a resource pack.
Icon/Theme Packs:
The Icon Packs are still basic and in development.
However, anyone can build and share there own custom packs.
containing:(remove anything from a pack u don't want patched, if a file or folder is not present it will simply not be patched)
~ A custom Logon screen
~ a custom side panel bitmap
~ Custom Copy/move/delete Animation colors
~ Custom taskmanager line and grid colors
~ A .themepack file, or a .theme file and folder
~ custom .ani/.cur Cursors or a complete cursor scheme
~ Any amount of .Res files
~ Install new fonts
~ Install new sounds
~ install sound schemes
any windir/ system32/ syswow64/ file can be added in .res format. e.g. "shell32.dll.res"
also these extra resfiles can be added to a pack in the resources folder:
~firefox.exe.res
~basebrd.dll.res
~shellbrd.dll.res
These packs can be installed and used via the options menu in the patcher.
[Base Pack] Pack=name of your custom pack Base by=name of pack creator Version=version number of your custom pack Date=date
[7tsp] theme creator=name theme=mytheme.theme <<The name of the theme file as placed in the "Extra" folder, e.g.: mytheme.themepack or mytheme.theme (and place the folder that goes with it "mytheme" also in the "Extra" Folder). mui=no << set to "yes" if u got any *.mui.res files in the resources folder uxhex=yes <<<In case the theme needs uxtheme.dll to be patched else write "no".
[taskmanager] grid=556677 <<<< only 6 characters correct hex values can be put here. memory=FF6A00 CPU=FF0000 Digits=FF0000
[CopyAnimation] color1=000000 color2=000035 color3=003C77 Fontcolor=FFFFFF or [CopyAnimation ] <<<<place a bitmap 100 (400x40) in shell32.dll.res to use a bitmap instead Bitmap=100 Fontcolor=FFFFFF
Se7en Theme Source Patcher
The Se7en Theme Source Patcher has been built from scratch, including the new res files and modifications made by Kirs.
We wanted a simple way to customize our complete OS, so we created 7tsp.
We've included internal Black resources in the patcher to have a more complete transformation
(this can be disabled in the options menu).
All internal resources are are just most of the basic white icons from Windows 7 turned black.
There are also color packs in development and available for download.
It's possible to create your own custom Theme/Icon pack's and apply them with the 7tsp GUI.
Modifications can include icons, bitmaps, cursors, a theme, side panel, logon screen and task manager colors.
The default pack is Black. You can select a custom pack in the Options menu.
It is also possible to merge your custom pack with the internal Black pack.
Restore: Restores the patched files to the backup made at 7tsp's first run.
For extra security, the patcher by default creates a Restore Point every time you patch your system.
You can disable this in the Options menu.
It is also possible to manually create a Restore Point (Program > Create Restore Point).
Logon Screen:
You can select whether the Logon screen should be patched or not, and you can also select a custom picture (a bmp. jpg. .png can be used from any given location and if needed will be converted and resized automatically).
Side Panel:
You can select whether the Side Panel should be patched or not, and you can also select a custom picture.(a bmp. jpg. .png can be used from any given location and if needed will be converted and resized automatically).
Cursors:
You can select whether or not the animated cursor files should be replaced. (add your own cursors to the cursors folder in a pack, open with eg 7z.exe and drag files out and in the opened 7z window)
Explorer.exe:
You can select whether or not Explorer.exe should be patched.
Debug log:
Here you can select whether or not a debug log should be created. This is useful for pack creators, to debug resfiles.
Clean Icon Cache:
When not all icons have changed, you can manually clean the icon and thumbnail cache to refresh these.
What happens to your system files:
1. If Start Patching is clicked, the Patcher will extract the selected resource pack to the work folder and look for each system file this pack will mod.( it will skip any file that is not in the resources folder in res format)
A backup will be made of those files in the case a backup does not yet exist. If Windows updated a file the backup will be updated as well.
2. The current file ownerships of a file are stored and then administrator ownerships are taken.
3. The file will be patched with the new resources and replaces the original file.
4. The file ownerships will be restored.
to do:
~Add task manager color change support
~Add more detailed start button support~Add GUI language support
~Add more res file support for other file locations then windir and sysdir when they are needed.
Hi all,
Icon/Theme Packs:
~ Install new fonts
~firefox.exe.res
~basebrd.dll.res
~shellbrd.dll.res
Download: 7tsp_GUI_v0.3_B(3003)
Extra Basic Color Packs
Download: 7tsp Black pack (a black (folder) icon pack which also can be used as example to build a custom icon pack)
MD5: b591a3d62604ae62d0b6f07330f56dad
Download: 7tsp Blue pack
MD5: 5398b644fbf7646ad6ddbdb7f3da954c
Download: 7tsp Green pack
MD5: 37074bfdba7bbeed206607c4252c7173
Download: 7tsp Red pack
MD5: d8fd07ffeccaddc053159fbc430cd41e
Download: 7tsp Purple pack
MD5: 01343f0326602b75b1a60ba0f00def21
Options
Start Patching: Patch your Windows 7
Logon Screen:
Side Panel:
Cursors:
Explorer.exe:
Debug log:
Clean Icon Cache:
to do:
Notes:
Windows 7 Only!
Please install the latest version of reshecker.
At the moment only live patching is supported.
Icons were modified using: IcoFX
Bitmaps were modified in: Paint.net and gimp
Regards
