J.S.Prasad Posted June 5, 2010 Posted June 5, 2010 (edited) Fresh HTML 3.55***************************************** Publisher: www.freshwebmaster.com License: Freeware Last Update: October16, 2010 Size: 3.58 MB (3,756,032 bytes)********************************Fresh HTML (Hypertext Markup Language) is a tool for webmaster to create pages for the world wide web. Its WYSIWYG (what you see is what you get) interface makes editing HTML pages as easy as using your favorite word processor. Its built-in editor allows advanced users to fine-tune HTML codes to fit their needs. This software is 100% free, no charge, no spyware, and updated regularly.Fresh HTML features:- CSS Styles inspector.- Tag Attributes inspector.- Button Generator Wizard.- Icon packs- Edit HTML through tree view interface.- Web site template- Spell check- Easier to create Table- ActiveX support- Java Applet support- Create marquee (running text), non W3C standard- Preview in browser- Background sound linking support (*.mid, *.wav, *.au), non W3C Standard- JavaScript/VBScript Files (*.js & *.vbs) linking support- JavaScript/VBScript editing support- Support media player, quick time, real media, and flash movie files- Easier to set auto-refresh for URL self or any URL- Easier to set robots meta- Easier to set URL base and window target base.- Easier to set LINK: StyleSheet, Default Icon, Next, Prev, etc. - Easier to fill in Meta keywords, description & author. You can use it to optimize your site in search engines's position.- Scheme color template for background, text, link. *For Switchless Installer extract the 7z archive and Run frhtml_silent.exe in SVCPACK folder. File: Frhtml_Addon_3.55.7z CRC-32: aee6daaf MD4: 1f25d8acd71a7c6c0495b97161719564 MD5: 66e830cadf1a7d5100944d2097e19f47 SHA-1: 6294b7e6e7f2e228e35d7ddadd6adc7d5bcc2f1c DownLoad: ->http://www.ziddu.com/download/12103775/Frhtml_Addon_3.55.7z.html ---------------------------------------------------------------Added auto registration to user "YOURSELF" Edited October 16, 2010 by J.S.Prasad Quote
J.S.Prasad Posted June 6, 2010 Author Posted June 6, 2010 The addon with reg entry may be downloaded Here http://www.mediafire.com/?n2hyvyzy4ytHash MD5: 0479250ed9ef51454afab10f8a1c5fa3 SHA-1: 54ce59b7674890e11f22e63a668cacec28399e80 Quote
