Posted June 7, 201014 yr Paint.NET RunOneEx AddOnPaint.NET is free image and photo editing software for computers that run Windows.It features an intuitive and innovative user interface with support for layers, unlimited undo,special effects, and a wide variety of useful and powerful tools. An active and growing onlinecommunity provides friendly help, tutorials, and plugins.Homepage: http://www.getpaint.net/index.htmlThe addon launches install of Paint.net on first boot in silent unattended mode.The addon can be modified to passive install at first boot with " -gm2 -ai2" switches.Paint.net requires Microsoft VC9++Runtimes and dotNET Framework 3.5SP1 to be installed.VC8+9_Addon: http://www.wincert.n...-vc10-runtimes/ Paint.Net_3.5.11_ROE_AddOn.cab MD5: 9222A19F16BDC98301E23AB0FB0B9F6BSize: 2,43 MBUrl.: http://ge.tt/api/1/files/2ajoSFp/0/blob?download
October 10, 201014 yr Author Added Lite version without VC9++ runtimesReuploaded Lite version for nLite compatibility 2010/10/25 Edited October 25, 201014 yr by jaynbe
November 21, 201014 yr Author Updated Paint.Net_3.5.6_Intl_ROE_Addon.cab Addons for Microsoft VC9 and .Net Framework 3.5SP1 required prior to Paint.Net
February 9, 201114 yr Author Oops...Renamed the entries.txt to entries.ini to have a working addonReuploaded today, redownload or rename the enties file inside.Still same installer requiring VC9 addon prior to integration.
February 21, 201114 yr Author Updated Paint.Net_3.5.7_Intl_ROE_Addon.cabAddons for Microsoft VC9 and .Net Framework 3.5SP1 required prior to Paint.Net_Addon Edited February 21, 201114 yr by jaynbe
March 6, 201114 yr Author Updated Paint.Net_3.5.8_Intl_ROE_Addon.cabMS-VC9 and .Net Framework 3.5SP1 required prior to Paint.Net.
October 2, 201113 yr Paint.Net 3.5.9 is released http://www.freewarefiles.com/PaintNET_program_13607.html
October 3, 201113 yr Author Updated Paint.Net_3.5.9_Intl_ROE_Addon.cabMS-VC9 and .Net Framework 3.5SP1 required prior to Paint.Net.
October 10, 201113 yr Author Updated Paint.Net_3.5.10_Intl_ROE_AddOn.cabMS-VC9 and .Net Framework 3.5SP1 required prior to Paint.Net.
November 12, 201113 yr Hello jaynbe. I tried this addon and it works perfect. But I have one question. I use Windows xp in spanish and the directory of installed programs is "Archivos de programa" and no "Program files". This addon install the program in "Program files", how I can change that?
November 12, 201113 yr Author kassyan_123,I had already noticed that behaviour caused by a hardcoded path in the installer.I have been trying changing the path in the MSI, but it returns errors for notfinding his database and the setup is being aborted.Finally I contacted the author, but as the problem doesn't occur on Win7,he denies the problem. Guess we'll have to live with it...Maybe, whenever I have more time, I'm going to look into it some more.
September 15, 201212 yr Author Modified installer with variable install path:Paint.Net_3.5.10.2_Intl_ROE_AddOn.cab
January 11, 201312 yr Author Modified installer with new ROE config; now default silent with ROE install box.(thanks for this hint to Geej) Paint.Net_3.5.10.3_Intl_ROE_AddOn
August 18, 201311 yr Author Updated Paint.Net_3.5.10_Intl_ROE_AddOn.cabMS-VC9 and .Net Framework 3.5SP1 required prior to Paint.Net.
