DesktopOK 2.33
Homepage - Save and Restore Desktop Icon Position
DesktopOK is a small but effective solution for user that have to change the screen resolution often.
Features:
Save your dearest icon locations for each screen resolution.
Each user can then have his own arrangement.
Minimises to tray area for easy access.
Launch at Windows startup (optional)
Autosave
DesktopOK does not have to be installed and can be executed easily from the desktop,
and can be carried on a small usb-stick or other memory device.
Additional: I included 1 autoit complied script (RDesktopOK.exe) and create a shortcut on user's desktop for quick restoration.
It is using mouseclick to restore base on latest setting only.
Start Menu for the main program (DesktopOK.exe) and RDesktopOK.exe are provided
DesktopOK.exe save your desktop icon setting in DesktopOK.ini. I supplied a general setting. Please replace DesktopOK.ini with your own setting before you slipstream.
Uninstallable via Add/Remove panel
Installed path: Program files\DesktopOK
DesktopOK233_INF_Addon.cab
Size: 330.45 Kb (338,381 bytes)
MD5: 056B0087466359747A1C786CD722E8D3
Edited by Geej
Just what ive been looking for. trying to use regedit tweak tools was driving me insane..
Another quality post by the main man Geej. Thank you !!
Edited by broonster
I have also experiment some tools to save desktop icons and I think this tiny program is the best & simplest to store/restore. Thanks for the kind words! Appreciated VM :)
  • 7 months later...
