TrojanHunter
Description
TrojanHunter®
TrojanHunter searches for and removes trojans from your system.
With an easy-to-use Scanner and a Guard that scans in the background
TrojanHunter is a must-have complement to your virus scanner. If you
are downloading files from the Internet, you need TrojanHunter!
Features
High-speed file scan engine capable of detecting modified trojans
Memory scanning for detecting any modified variant of a particular build of a trojan
Registry scanning for detecting traces of trojans in the registry
Inifile scanning for detecting traces of trojans in configuration files
Port scanning for detecting open trojan ports
The Advanced Trojan Analyzer, an exclusive feature of TrojanHunter, is able to find whole classes of trojans using advanced scanning techniques
TrojanHunter Guard for resident memory scanning - detect any trojans if they manage to start up
LiveUpdate utility for effortless ruleset updating via the Internet
Process list giving details about every running process on the system, including the path to the actual executable file
Accurate removal of all detected trojans - even if they are running or if the trojan has injected itself into another process
Built-in netstat viewer
Extensive help files
Free technical support via e-mail
Version: 5.3.0.994
Addon Release Date: June 29, 2010
Uninstallable: Yes
Credit: *Reaper*
This is FULLY updated with the newest definition files.
NOTE: This will install as a trial. If you would like to have it
installed as a registered version, just unzip my addon, copy your
License.tlf file to the TrojanHunter 5.3 directory, then rezip the
addon.
size0normal.jpg 21.8 MB
md50normal.jpg 9ec77f37311270e4554dad3acdfd1e0e
Enjoy!
Edited by *Reaper*
