Posted June 26, 201014 yr I got some notes on deviantart that people wanted some things done to my old cad 2009 edition v1.6, that they want to change the font color to what they want. So I thought of bringing the project back, so now it will be named cad 2010 edition, I never thought I would have to bring the project back after making cad 2009 edition v1.6 final, but I have been so bored anyway so there is not problem of doing this of re-newing the project... I have taken out the icon folder so far and the png folder, so now you will need like resource hacker to mod the images in cad 2010 edition. this way it was more easy to manage the project. I have also taken out the sounds folder, now that will also require resource hacker to change the wave files in the project. So far it's coming around nicely, I have been wanting to make the backgrounds for cad 2010 edition to be part of the res file inside of cad2010.exe, the only problems im running into is getting the program to detect the correct resolution and change it, or if it can not find the background to choose a different one. The main reason I posted this forum is to let people know about the new project, and what else would people like to be done for changes from v1.6 to this new project? Please ask any questions if you have any.The new CAD 2010 EDITION has a new setup method like how vistart from lee-soft the OneStep setup.Location to cad 2009 edition v1.6http://www.flawless02.deviantart.com Edited June 29, 201014 yr by Flawless02
June 27, 201014 yr Hello, i want to have support for all languages => when i translate language.txt not all letters are showing correct. Can you add support for all char coding? Edited June 27, 201014 yr by George King
June 27, 201014 yr Author Hello, i want to have support for all languages => when i translate language.txt not all letters are showing correct. Can you add support for all char coding?Yes, im working on the configuration area in language.txt right now so you can:change colorchange sizechange font typeSo maybe that will make it work correctly in all languages.
June 28, 201014 yr Yes, im working on the configuration area in language.txt right now so you can:change colorchange sizechange font typeSo maybe that will make it work correctly in all languages.That sounds nice
June 29, 201014 yr Author I need to really know this...What part of the program does the text not appear correctly?And What language are you trying to translate it to?
July 6, 201014 yr Sorry for delay, here are screens with bugs... I used latest version of CAD 2010 and i tried translate it into CZECH language And here is language.txt, i think it can help you to fix these bugs...CAD 2010 Edition v1.7Czech (Če
July 6, 201014 yr Author Did you try to change the font type in the language.txtI hope this is beta 2 that your using lol.Find out what font type that your text language is in.Im not sure I know like people that are from russia had problems as well with the type of fonts like the text didn't show up correctly, I would try a different font type, first thing to try to do is find out what type of font that shows up correcly for your language.Like try it out in notepad change font until it comes up. then use the font type.Another thing you can do is send me your language.txt and keep your language on it for me to try, im on Windows 7, and I wanna see if it does anything different, it could be just a font issue that I don't know of like a out dated font file. Im really not sure I only speak english, But thanks for showing me both of how it looks and how it should look, I asked the guy from russia to do the same and he didn't understand me or something, because I don't know how it should look, you know. But I do see how it's different from your screen shots. Edited July 6, 201014 yr by Flawless02
August 30, 201014 yr Since I used the 2009 version on my nlite XP.. does this one have silent switches or anything?
September 20, 201014 yr Author Since I used the 2009 version on my nlite XP.. does this one have silent switches or anything?CAD 2010 EDITON uses switches.. if your talking about like shortcut targetsif you launch it from a shortcut it is "C:\Program Files\CAD 2010 EDITION\cad2010.exe" -lockcomputerand the other switch is -changepasswordthis is for the v2.0 Edited September 20, 201014 yr by Flawless02
September 20, 201014 yr Hey man, i tried translate version v2.0 using Restorator and i got the same results as before. Some letters aren
September 21, 201014 yr Ok maybe it's me but I can't seem to make task manager working with this installed..Ok sorry but an edit too.. NIS 2010 removed the taskmanger in the CAD folder Edited September 21, 201014 yr by wolfsoul
March 28, 20159 yr I tried the following - deactivating video - loaded video file - music plays - ctrl-alt-delete: music still plays - activated video - loaded video file - video plays - ctrl-alt-delete: video crashes Also, I verified that this crashes on another SP3 machine. Hope this helps
