*Reaper* Posted June 26, 2010 Posted June 26, 2010 (edited) Malwarebytes' Anti-MalwareDescriptionMalwarebytes' Anti-Malware is considered to be the next step in the detection and removal of malware. In our product we have compiled a number of new technologies that are designed to quickly detect, destroy, and prevent malware. Malwarebytes' Anti-Malware can detect and remove malware that even the most well known anti-virus and anti-malware applications fail to detect. Malwarebytes' Anti-Malware monitors every process and stops malicious processes before they even start. The realtime protection module uses our advanced heuristic scanning technology which monitors your system to keep it safe and secure. In addition, we have implemented a threats center which will allow you to keep up to date with the latest malware threats.ChangelogIssues Fixed--------------------------------------------------------------------------------1.Fixed issue with the scheduler not performing realtime updates.2.Fixed multiple issues with product crashing during a scan.3.Fixed issue with log not saving on certain command line scans.4.Fixed various issues with Finnish, Italian, and Norwegian languages.5.Fixed formatting and misspelling issues in product help file.Version: 1.50.1.1100Addon Release Date: May 28, 2011Uninstallable: YesCredit: *Reaper*This is FULLY updated with the newest definition files.NOTE: This will install as the free version. If you would like to have itinstalled as a registered version, just unzip my addon, open malware.reg with notepad,the very first entry looks like this:;[HKEY_LOCAL_MACHINE\SOFTWARE\Malwarebytes' Anti-Malware];"ID"="xxxxxxxxxxxxxxxxxxxxxxxxxxxx";"Key"="xxxxxxxxxxxxxxxxxxxxxxxxxxx"Remove the ";" from in front of each line.Add your ID and you Key where the "xxxxxxxxx" are, then save the file and rezip the addon.When your done, the reg file should look something like this..[HKEY_LOCAL_MACHINE\SOFTWARE\Malwarebytes' Anti-Malware]"ID"="123abc""Key"="abcd-abcd-abcd-abcd" 8.04 80527c9e7f3f2a43de4880dd1acca563Enjoy! Edited May 28, 2011 by *Reaper* makoulis 1 Quote
*Reaper* Posted December 26, 2010 Author Posted December 26, 2010 Updated to 1.50.1.1100Updated to the newest definition files also. Quote
compstuff Posted March 25, 2012 Posted March 25, 2012 Hi Reaper... I never created an addon but before I tried with this one I was wondering if this was the method you used or if you could provide some insight... thankshttp://www.wincert.net/forum/index.php?/topic/5833-guide-creating-addons/ Quote
Triptych Posted June 29, 2012 Posted June 29, 2012 ._. Mediafire's giving me an error. Could you reupload? Quote
ErixGamer Posted July 1, 2012 Posted July 1, 2012 can u re-upload the file because mediafire give's an error Quote
Kelsenellenelvian Posted August 6, 2013 Posted August 6, 2013 Well, considering this addon was last updated 2.5 years ago....... Quote
MAXtoriX Posted June 20, 2014 Posted June 20, 2014 @*Reaper*: Can you make updated addon (ver.2.0.2) of this software? Quote
