Emote Maker (or EM) is an application that anyone can use to make unique, stylish, customized emoticons. The application has been under creation for over a year and has
many features which you can initialise on over 100 assorted emoticon objects!
Emote Maker is probably the first emoticon creation tool to offer a massively advanced amount of effects, you can rotate, flip and even blend colours into all the objects in the program and objects that you import from image files!!
Emote Maker offers many exporting options, you can export your emoticons to be used on your website, chat room, forum, blog, E-Mail or practically anything that allows the use: GIF, JPEG, PNG and BMP image files.
The most exciting thing is that you can make animated emoticons with Emote Maker, YES upto 10 frames of animation!! Not only that but Emote Maker has an option to create your animation for you so it runs without you having to combine seperate files afterwards!
  • 7 months later...
