Ken@fri Posted June 28, 2010 Share Posted June 28, 2010 (edited) Hi everybody !After 1 month of hard work, I finally finished my Nero Multimedia Suite 10 Lite Edition addon.But, one last step remaining before I share it with members of this community : add internationalization support. So I need your help to translate strings below in following languages (English (ENU) & French (FRA) are OK):German (DEU)Spanish (ESP)Dutch (NLD)Italian (ITA)Polish (PLK)Portuguese (PTB)Turkish (TRK);======================== Localizable ==================================APPS_HLP ="Nero\Users Manuals"NeroMultimediaSuite10LiteEd_Tip ="Nero 10 Lite Edition Software Suite includes a selection of the following components: Nero 10 Lite Edition, Nero Multimedia Tools"Nero10LiteEd_Tip ="Nero 10 Lite Edition includes the following components : Nero Burning ROM, Nero Express, Nero CoverDesigner, Nero ControlCenter, Nero WaveEditor";===============NeroBurningROM_Tip ="THE Ultimate and legendary media Burner"NeroExpress_Tip ="Easy wizard guided optical disc burning and copying"NeroBROM_WARNING ="WARNING : continuing with this operation will completely remove Nero Burning ROM (main component) and ALL which are dependent for it"NeroDesk_Tip ="THE Perfect Burner!"NeroEx_Tip ="Nero Express is powered by the ultimate Nero burning engine using a wizard-style user interface. Burn your audio, data and video discs in one go"NeroBROM_hlp_Tip ="Nero Burning ROM - Help"NeroEx_hlp_Tip ="Nero Express - Help"Add.NeroShellExt ="Add command - Burn with Nero - to context menu"Del.NeroShellExt ="Remove command - Burn with Nero - from context menu"Add.NeroShellExt_Tip ="Add Nero burning commands to Windows context menu"Del.NeroShellExt_Tip ="Remove Nero burning commands from Windows context menu";---------------NeroCoverDes_Tip ="Allows you to create and to print labels or covers for your CD/DVD/Blu-Ray"NeroCD_Tip ="A user-friendly program for creating and designing individual covers and labels. You can use your own ideas to create CD/DVD/Blu-Ray covers, booklets or you can import covers from your scanner, digital camera or the Internet"NeroCD_hlp_Tip ="Nero Cover Designer - Help";---------------NeroWavEdit_Tip ="Allows you to record and edit audio files"NeroWE_Tip ="Cut, clean and edit your audio files with professional tools"NeroWE_hlp_Tip ="Nero Wave Editor - Help";===============NeroMultimediaTools_Tip ="Nero Multimedia Tools includes the following Nero Extra components : Nero BurnRights, Nero DiscSpeed, Nero InfoTool";---------------NeroBurnRights_Tip ="Allows a system administrator to authorize users without administrator rights to burn discs and connect new burners"BrnRite_Tip ="Allows a system administrator to manage CD/DVD/Blu-Ray burning rights"BrnRite_hlp_Tip ="Nero BurnRights - Help" ;---------------NeroDiscSpeed_Tip ="Allows you to determine the speed of your CD/DVD/Blu-Ray drives"DiscSpeed_Tip ="You can test the speed and performance of your drive with a series of professional testing routines"DiscSpeed_hlp_Tip ="Nero DiscSpeed - Help";---------------NeroInfoTool_Tip ="Provides you with information about the most important features of installed drives, inserted discs, installed software, and much more"InfoTool_Tip ="Find out all about your(s) drive(s) and your system configuration"InfoTool_hlp_Tip ="Nero InfoTool - Help";---------------NeroCtrlCenter_Tip ="Keep Nero up to date"NeroCtrlCenter_hlp_Tip ="Nero ControlCenter - Help";addoner_strings ="Addon created by Ken@fri aka Xtr3mnician";--------------------- REGISTRATION INFOS ---------------------------------; Trial version ONLY;-------------------- Installation/Uninstallation Prompts -----------------Loc_MainApp_InsQuest ="Do you want to install Nero Multimedia Suite 10 Lite and all its components?"Loc_MainApp_EndInsPrompt ="Congratulations, Nero Multimedia Suite 10 Lite was successfully installed!"Loc_InsTitle ="Installation"Loc_UninsTitle ="Uninstallation"Loc_Apps_UninsQuest ="Do you want to uninstall"Loc_Apps_EndUninsPrompt ="was successfully uninstalled"Loc_UninsQuest ="Do you want to continue and uninstall Nero Multimedia Suite 10 Lite and all of its components?"NeroSuite10Lite_UninsPrompt ="WARNING : continuing with this operation will completely remove Nero Multimedia Suite 10 Lite"Thanx :worthy: Edited June 28, 2010 by Ken@fri Quote Link to comment Share on other sites More sharing options...
MISTER X Posted August 29, 2010 Share Posted August 29, 2010 (edited) Italian (ITA) localization (corrected):;======================== Localizable ==================================APPS_HLP ="Nero\Manuali Utente"NeroMultimediaSuite10LiteEd_Tip ="Nero 10 Lite Edition Software Suite comprende una selezione delle seguenti componenti: Nero 10 Lite Edition e Nero Multimedia Tools"Nero10LiteEd_Tip ="Nero Lite Edition 10 comprende i seguenti componenti: Nero Burning ROM, Nero Express, Nero CoverDesigner, Nero ControlCenter, Nero WaveEditor";===============NeroBurningROM_Tip ="L'ultimo software di masterizzazione!"NeroExpress_Tip ="Semplice procedura guidata di masterizzazione e copia dischi ottici"NeroBROM_WARNING ="ATTENZIONE: continuando con questa operazione sarà rimosso completamente Nero Burning ROM e tutti i suoi componenti"NeroDesk_Tip ="THE Perfect Burner!"NeroEx_Tip ="Il modo più facile e veloce per scrivere ogni disco audio, dati e video, fare backup di dischi completi e molto altro"NeroBROM_hlp_Tip ="Nero Burning ROM - Aiuto"NeroEx_hlp_Tip ="Nero Express - Aiuto"Add.NeroShellExt ="Aggiungi il comando - Masterizza con Nero - al menu contestuale"Del.NeroShellExt ="Rimuovi il comando - Masterizza con Nero - al menu contestuale"Add.NeroShellExt_Tip ="Aggiungere il comando di masterizzazione Nero al menu contestuale di Windows"Del.NeroShellExt_Tip ="Rimuovere il comando di masterizzazione Nero al menu contestuale di Windows";---------------NeroCoverDes_Tip ="Disegna e stampa etichette o copertine perfette per i tuoi dischi"NeroCD_Tip ="Un programma di facile utilizzo per la creazione e la progettazione di singoli copertine ed etichette. È possibile utilizzare le proprie idee per creare CD/DVD/Blu-Ray copertine, booklet oppure importare copertine dallo scanner, macchina fotografica digitale o su Internet"NeroCD_Tip ="Un'applicazione avanzata per creare elementi di copertina personalizzati quali booklet, inlay ed etichette"NeroCD_hlp_Tip ="Nero Cover Designer - Aiuto";---------------NeroWavEdit_Tip ="Consente di registrare e modificare i file audio"NeroWE_Tip ="Taglia, pulisci e modifica i file audio con strumenti professionali"NeroWE_hlp_Tip ="Nero Wave Editor - Aiuto";===============NeroMultimediaTools_Tip ="Nero Multimedia Tools include i seguenti componenti Nero extra: Nero BurnRights, Nero DiscSpeed, Nero InfoTool";---------------NeroBurnRights_Tip ="Consente all'amministratore di sistema di garantire agli utenti senza diritti di amministrazione l'autorizzazione per masterizzare dischi e collegare nuovi masterizzatori"BrnRite_Tip ="Consente all'amministratore di sistema la gestione dei diritti di masterizzazione dei CD/DVD/Blu-Ray"BrnRite_hlp_Tip ="Nero BurnRights - Aiuto" ;---------------NeroDiscSpeed_Tip ="Prova le prestazioni e la qualità del drive"DiscSpeed_Tip ="Verifica velocità e prestazioni del tuo drive con una serie di routine di testing professionali"DiscSpeed_hlp_Tip ="Nero DiscSpeed - Aiuto";---------------NeroInfoTool_Tip ="Nero InfoTool consente di richiamare le informazioni sulle funzioni più importanti delle unità installate, dei dischi inseriti, del software installato e molto altro ancora"InfoTool_Tip ="Mostra tutte le informazioni sul drive e sulla configurazione di sistema"InfoTool_hlp_Tip ="Nero InfoTool - Aiuto";---------------NeroCtrlCenter_Tip ="Mantieni aggiornato Nero"NeroCtrlCenter_hlp_Tip ="Nero ControlCenter - Aiuto";; Dir Xtr3mAddOnRes' background; bkgrnd ="Sfondo"bkgrnd ="Background"addoner_strings ="Ken@fri aka Xtr3mnician"LCID ="it-IT"LCID2 ="it-IT"LCID3 ="it-IT"LCID4 ="it-IT"; Bi_LCID ="en-US,it-IT"LANG_CODE ="1040"; LOC ="ITA"LANG ="ITA"LNG ="it"LNG2 ="it"LNG3 ="it"LNG4 ="it"; HlpFile_Ext ="chm"NeroBROM_Desc = "Nero Burning ROM consente di masterizzare ed eseguire il backup in modo rapido e sicuro di musica, dati e video in tutti i formati più comuni"NeroEx_Desc = "Nero Express è un'applicazione intuitiva con procedure guidate che consente di masterizzare musica, dati e video in un unico passaggio"NeroCC_Desc = "Nero ControlCenter è l'applicazione per l'aggiornamento e la modifica della configurazione dei prodotti Nero"CoverDes_Desc = "Nero CoverDesigner consente di creare copertine ed etichette per CD e DVD personalizzate con immagini provenienti dallo scanner, dalla fotocamera digitale o da Internet"NeroDiscSpd_Desc = "Con una serie di strumenti professionali, Nero DiscSpeed consente di eseguire il test della velocità e delle prestazioni delle unità disco ottico"WaveEdit_Desc = "Nero WaveEditor è un programma per la modifica e la registrazione dei file audio. I diversi metodi di applicazione dei filtri e di ottimizzazione del suono consentono di creare singoli file audio in modo facile e veloce"CopyCD_Action = "Copia CD"CreateDisk_Action = "Crea disco personale"CDC_Desc ="Compilation Nero CoverDesigner"NCD_Desc ="Documento di Nero CoverDesigner Document"NCT_Desc ="Modello Nero CoverDesigner"NCW_Desc ="File procedura guidata Nero CoverDesigner"CUE_Desc ="File di immagine"IMG_Desc ="File di immagine"ISO_Desc ="File di immagine"NAB_Desc ="Compilation Audiolibro CD-ROM"NBS_Desc ="Compilation CD-ROM (SecurDisc)"NBV_Desc ="Compilation BDMV"NCP_Desc ="Check Point Compilation"NHB_Desc ="Compilation AVCHD(TM) BD"NHD_Desc ="Compilation AVCHD(TM) DVD"NHF_Desc ="Compilation CD HFS"NHV_Desc ="Compilation HD-BURN-Video"NMD_Desc ="Compilation miniDVD"NR3_Desc ="Compilation CD-ROM (MP3)"NR4_Desc ="Compilation CD-ROM (AAC)"NRA_Desc ="Compilation CD-Audio"NRB_Desc ="Compilation CD-ROM (avvio)"NRC_Desc ="Compilation CD-ROM (UDF/ISO)"NRD_Desc ="Compilation DVD-Video"NRE_Desc ="Compilation CD EXTRA"NRG_Desc ="CD di immagine"NRH_Desc ="Compilation CD-ROM (ibrido)"NRI_Desc ="Compilation CD-ROM (ISO)"NRJ_Desc ="JukeBox Compilation"NRM_Desc ="Compilation Mixed Mode CD"NRS_Desc ="Compilation CD-ROM (avvio EFI)"NRU_Desc ="Compilation CD-ROM (UDF)"NRV_Desc ="Compilation Video-CD"NRW_Desc ="Compilation CD-ROM (WMA)"NSD_Desc ="Compilation Super Video CD"NWF_Desc ="File Nero WaveEditor";--------------------- REGISTRATION INFOS ---------------------------------; Trial version ONLY; DEMO_SERIAL ="8X01-2060-E61P-05UX-HEP8-9AU4-K34W-CZUU"; DEMO_SERIAL ="8M01-20CX-4294-TL10-U4U0-UKE2-MMT7-AHWX"YOUR_SERIAL ="";-------------------- Installation/Uninstallation Prompts -----------------Loc_MainApp_InsQuest ="Installare Nero Multimedia Suite 10 Lite e tutti i suoi componenti?"Loc_MainApp_EndInsPrompt ="Congratulazioni, Nero Multimedia Suite 10 Lite è stato installato correttamente!"Loc_InsTitle ="Installazione"Loc_UninsTitle ="Disinstallazione"Loc_EndUninsPrompt ="è stato rimosso con successo"Loc_UninsQuest ="Vuoi continuare e disinstallare Nero Multimedia Suite 10 Lite e tutti i suoi componenti?"NeroSuite10Lite_UninsPrompt ="ATTENZIONE: continuando con questa operazione sarà rimosso completamente Nero Multimedia Suite 10 Lite"Loc_Apps_UninsQuest ="Si desidera rimuovere completamente"Loc_Apps_EndUninsPrompt ="è stato installato correttamente"Quest_Mark ="?"Exclam_Mark ="!"Bon travail Edited August 29, 2010 by MISTER X Quote Link to comment Share on other sites More sharing options...
Ken@fri Posted September 29, 2010 Author Share Posted September 29, 2010 [quote name='MISTER X Quote Link to comment Share on other sites More sharing options...
SysSistem Posted October 1, 2010 Share Posted October 1, 2010 (edited) Spanish Well I hope to be helped, my English is not good, hoping that if there some flaws in the translation is Corega Please:);======================== Localizables ================================== APPS_HLP = "Nero \ Manuales Para Usuarios"NeroMultimediaSuite10LiteEd_Tip = "Nero 10 Lite Edition Software Suite incluye una selecci Edited October 1, 2010 by SysSistem Quote Link to comment Share on other sites More sharing options...
Ken@fri Posted October 1, 2010 Author Share Posted October 1, 2010 Spanish Well I hope to be helped, my English is not good, hoping that if there some flaws in the translation is Corega Please:)Thanx for u'r help . Quote Link to comment Share on other sites More sharing options...
