Posted (edited)
Defraggler
Description
Use Defraggler to defrag your entire hard drive, or individual files - unique
in the industry. This compact Windows application supports NTFS and FAT32 file systems.
Features
Defragment exactly what you wantMost defrag tools only allow you to defrag an entire drive. Defraggler lets you specify one or more files, folders, or the whole drive to defragment.Safe and SecureWhen Defraggler reads or writes a file, it uses the exact same techniques that Windows uses. Using Defraggler is just as safe for your files as using Windows.Small and lightweightDefraggler's tough on your files – and light on your system.Interactive drive mapAt a glance, you can see how fragmented your hard drive is. Defraggler's drive map shows you blocks that are empty, not fragmented, or needing defragmentation.Quick DefragGive your hard drive a quick touch-up with Quick Defrag.Defragment free spaceOrganizes empty disk space to further prevent fragmentation.Scheduled defragmentationDefragment while you sleep - and wake up with a faster PC. Set Defraggler to run daily, weekly or monthly.Full Windows OS and Multi-lingual supportNo matter what your native tongue is, Defraggler speaks your language. It currently supports 37 languages.
[b]v2.14.706 (23 Apr 2013) - Added Freespace Defrag to scheduler.  - Added single-click analysis of multiple drives.  - Added support for UDF file systems.  - Improved searching with wildcards.  - Improved shell extension on 64-bit systems.  - Improved GUI navigation.  - Fixed minor bug in the monthly scheduler.  - Minor improvements and bug fixes.[/b]
Version: 2.14.706
Addon Release Date: June 2, 2013
Uninstallable: Yes
Credit: *Reaper*
size.jpg1.37 MB
md5.jpg71385baf4e03b1fafe63c058af2fbf7e
size.jpg1.22 MB
md5.jpg79667145cc3f6cbb1c9a7513081b2edc
Enjoy!
Edited by *Reaper*
  • 1 year later...
  • 10 months later...
  • 5 months later...
  • 6 months later...
  • 1 year later...
