hello
sir
i am new here, i watch video tutorial from here for making silent install addon with evry time i make addons for new softwares like picasa i get this screen select one installer i dont noe what to do ?
so i try universal switch finder but same problam here
plz help me experts same problem with new software like firefox pdfreader and other
my net is very slow so i am not able to download addons form mediafire i gt 3kbps speed
plz help me to solve my problem plz sir
A gr8 site to look for info on silent switch installs is appdeploy.com
http://www.google.com/search?q=appdeploy+picasa
picasa.exe /S for silent installation
Above Entry Provided on 4/21/2006 by nikpait Rate It
Rating
118
If the /S switch is used Picasa automatically starts up.
Above Entry Provided on 5/19/2006 by anoat1970 Rate It
Rating
117
The uninstall is not completely quiet as it still asks if you wish to remove the database
Using the /S gets rid of all of the prompts except for the Yes/No for the database as stated above.
Above Entry Provided on 5/23/2007 by jcnwml Rate It
Rating
119
Be aware that the /S switch must be written in upper case.
Above Entry Provided on 11/29/2007 by NTX Rate It
Rating
120
You can add /L to it so it doesn't launch picasa. So it would be
picasa.exe /S /L
Above Entry Provided on 9/28/2009 by sk1 Rate It
Rating
6
It's possible to make additionals options to the register after installation.
[HKEY_CURRENT_USER\Software\Google\Picasa\Picasa2\Preferences]
"AutoUpgradeAsk"=dword:00000001
"AutoUpgradeCheck"=dword:00000000
"ReportStats"=dword:00000000
"newfeatureslink"=dword:00000000
This make:
No Silent Upgrade for Picasa
No Automatic Upgrade for Picasa
No Question for ReportStats to the first opening
No Help on website Picasa to the first opening
