Posted (edited)
Hi,can someone help with this? I want to remove components in 1 session and i want know, which component cant be removed via vlite for working OnePiece AIO Update Pack
Who can help with it?
Components in OnePiece Pack:
WinMFC ;Windows Management Framework Core Top level option
OPMWXPUP
BrowserChoice
WinRM
PowerShell
PowerShellISE
MicrosoftUpdate
Silverlight
DirectX
MDX
MSXML4
WDSearch
IMAPI2
ICCDSCD
WgaNotify
WRMC
BitLockerToGo
or another list:
KB817688 - "Error on a Request to Write Data to Media" error message when you use Ntbackup.exe
KB887606 - FIX: The Microsoft XML Parser (MSXML) uses cached credentials incorrectly
KB889320 v2 - When you disable the Windows Firewall service on your Windows XP Service Pack 2-based computer, the Computer Browser service stops after five minutes and Event ID 7023 is logged in the Event Viewer
KB897571 - FIX: A DCOM static TCP endpoint is ignored when you configure the endpoint for WMI on a Windows Server 2003-based computer
KB898461 - Software update 898461 installs a permanent copy of the Package Installer for Windows version 6.1.22.4
KB909520 v1 - Description of the software update for Base Smart Card Cryptographic Service Provider
KB915800 v4 - A hotfix is available for Windows Desktop Search document IFilters in Windows XP and Windows Server 2003
KB916157 v6 - When you receive a Stop error message or a fatal system error message, a user-mode process dump file is not created in Windows XP
KB922120 v6 - Network Map in Windows Vista does not display computers that are running Windows XP
KB923561 - MS09-010: Description of the update for Windows WordPad Converter: April 14, 2009
KB932716 v2 - Description of the Image Mastering API v2.0 (IMAPIv2.0) update package that is dated June 26, 2007
KB934401 - When you run the "Ipconfig /displaydns" command in Windows Server 2003, the results are incomplete
KB940648 - Error message when you try to open the My Documents folder on a Windows XP-based computer after you resume the computer from hibernation: "You might not have permission to use this network resource"
KB942288 v3 - Windows Installer 4.5 is available
KB943232 v2 - An application that uses the Sxs.dll file crashes when you run the application on a Windows XP SP 2-based computer
KB944043 v3 - Description of the Windows Server 2008 read-only domain controller compatibility pack for Windows Server 2003 clients and for Windows XP clients
KB945060 v3 - There may be inconsistencies in the Extensible Metadata Platform (XMP) and Exchangeable Image File (EXIF) values for an image file in Windows Vista and in Windows XP
KB945184 - The Rasdial API may free the same memory two times and the dial-up application stops responding on a multiprocessor computer that is running Windows Vista
KB945436 - Error message when you try to uninstall or unload the driver for a multifunction USB device on a Windows XP-based computer: "STOP: 0x000000D1 DRIVER_IRQL_NOT_LESS_OR_EQUAL"
KB946648 - MS08-050: Description of the update for Windows Messenger 4.7 for Windows XP: August 12, 2008
KB947460 v3 - Error message when you try to open a mapped DFS folder after the computer comes out of standby in Windows XP Service Pack 2: "<Drive Letter>:\ is not accessible"
KB948101 v3 - A USB keyboard does not work after you restart a Windows XP-based computer that has an NVIDIA 680i motherboard installed
KB948277 - A blank desktop may appear when you log on to a Windows XP-based computer
KB948720 - You cannot install device drivers in a Windows Server 2008 cluster environment if the drivers contain LZ-compressed files
KB948877 v2 - After you copy multiple files from a computer that is running Windows XP to a PCMCIA SRAM card, one or more files on the card are corrupted
KB949127 v2 - You cannot establish a wireless connection by using EAP authentication on a Windows XP-based client computer if the Service Set Identifier (SSID) includes a comma
KB949900 - The RunOnce.exe process may stop responding during the driver installation process on a Windows XP-based computer
KB950305 v2 - A Word document is not printed as expected after installing the Windows European Union Expansion Font pack
KB950312 - Error message when you try to start a console-based application, such as Cmd.exe, on a Windows XP-based computer: "The application failed to initialize properly (0xc0000142)"
KB950616 - An audio application that uses the Portcls.sys file may stop responding when you run the audio application on a computer that is running Windows XP
KB950820 - The system stops responding during the logoff, shutdown, or restart process on a computer that is running Windows Server 2003 or Windows XP and that has the Japanese IME installed
KB950974 - MS08-049: Vulnerability in Event System could allow remote code execution
KB950982 - A list of ODBC system DSNs is truncated when the total number of characters that are used in all the DSN names is more than 7,500 on a Windows XP-based computer
KB951159 - n/a
KB951163 - When you try to use the MSTSC command from Terminal Services Client 6.0 to connect to the local Windows XP-based computer, a black screen may appear for several minutes
KB951347 - A memory leak occurs when you use the IFaxIncomingMessageIterator interface to query incoming fax messages on a fax server that is running Windows Server 2003 or Windows XP
KB951376 v2 - MS08-030: Vulnerability in Bluetooth stack could allow remote code execution
KB951531 v2 - The W32Time service does not synchronize the CMOS clock time to the Internet time on a Windows XP or Windows Server 2003-based computer after the W32Time service stops
KB951618 v2 - A black screen issue occurs on a Windows Vista-based computer or a Windows XP Service Pack 2-based computer that has Onekey Recovery 5.0 installed when you upgrade the operating system
KB951624 - A 30-second delay occurs during the initialization of some network-based applications when Windows XP Service Pack 2 starts
KB951709 - Event ID 26 when you attach two IDE ATA/ATAPI devices as master and subordinate IDE devices on a Windows XP-based computer
KB951822 v2 - You receive an error message, the print operation fails, or partial pages are printed when you try to print to a Citizen printer or to an Alps printer in Windows XP Service Pack 3
KB951978 - Script output is not displayed as expected when you run VBScript or JScript scripts in Windows Vista Service Pack 1, in Windows Server 2008, or in Windows XP Service Pack 3
KB952004 - MS09-012: Description of the security update for MSDTC Transaction Facility: April 2009
KB952117 v2 - When you try to put a Windows XP-based computer into hibernation or into standby, the computer stops responding
KB952595 v3 - n/a
KB952954 - MS08-046: Vulnerabilities in Microsoft Windows Image Color Management could allow remote code execution
KB953028 - On a computer that is running Windows Server 2003 or Windows XP, an application experiences an access violation and then crashes if the computer has more than four cores or more than four logical processors
KB953155 - MS08-062: Vulnerability in Windows Internet Printing service could allow remote code execution
KB953761 - Some DHCP Options are not recognized on a Windows XP SP3-based client computer when the DHCP server offer includes option 43
KB953930 - The Fc.exe command does not work correctly on a Windows XP-based computer when the two files that you are comparing have the TAB or SPACE character around the 128th byte in a string of characters
KB954193 - Description of the Jet 4.0 Database Engine cumulative hotfix package for Windows XP SP2 and SP3, Windows Server 2003 SP1 and SP2, Windows Vista, Windows Vista SP1, and Windows Server 2008: July 2, 2008
KB954232 - The On-Screen Keyboard behavior on a Windows XP-based computer does not mimic the physical keyboard behavior in certain scenarios
KB954434 - A multiprocessor computer that is running a Windows XP, Windows Server 2003, or Windows Vista stops responding on a black screen after you resume the computer from hibernation
KB954708 - An update to add support for the serialization of complex Extensible Metadata Platform (XMP) data types in the Windows Imaging Component
KB954920 v2 - When an application requests a result set from new SQL Server 2008 collations, you may receive an "MSG 40242" or "MSG 40205" error when the ODBC driver for SQL Server is used or an "MSG 40234" error when the SQL OLE DB provider is used
KB955109 - Error message when you run an application that uses the Application Desktop Toolbar (AppBar) component on a computer that is running Windows XP SP2 or Windows XP SP3:
Edited by George King
OPMWXPUP
BrowserChoice
WinRM
PowerShell
PowerShellISE
MicrosoftUpdate
Silverlight
DirectX
MDX
MSXML4
WDSearch
IMAPI2
ICCDSCD
WgaNotify
WRMC
BitLockerToGo
Well see considering that nLite doesn't know what MOST of these things even are you will HAVE to just buckle down and use the RVMi...
