Logysis Finger Mouse
Those mini mice that fit in your fingers have met their match. Logisys has developed the new 800 DPI Optical finger mouse which fints on your index finger and works with simple movements. (if moving your wrist has gotten taxing). Virtually works on any media except reflective glass surface. \
Strap it on your index finger with the sensor tip in alignment with your index finger tip or slightly higher depending on your own comfort level.
Provide support by using your middle finger to hold the finger mouse against your index finger when you are clicking.
Point the cursor with your index finger while your thumb to control the left button ( lower button), right button ( upper button) and scroll wheel.
