Foxit Reader v6.1.1.1031 (final update by me)
Whether you're a consumer, business, government agency, or educational organization, you need to read and annotate PDF documents and fill out PDF forms. You need your PDF Reader to be:
•Fast - so you're not waiting forever to read files.
•Lightweight - so it's easily deployable and doesn't exhaust system resources.
•Secure - so you don't get infected with viruses and can keep sensitive information safe.
•A Platform - so you can extend the Reader by creating your own value added capabilities for internal use or for resale.
The Foxit Reader is a small, fast, and feature rich PDF viewer which allows you to open, view, and print any PDF file. Unlike other free PDF readers, Foxit Reader also includes easy to use collaboration features like the ability to add annotations, fill out forms, and add text to PDF documents. Foxit Reader has a small footprint that starts up instantly, renders PDF files quickly and uses very little memory, which is especially important with today's handheld devices. The Foxit Reader is packed full of convenient and easy to use viewing, editing and printing features that make document collaboration simple. Foxit Reader's secure platform insures worry free operation against malicious virus and provides a secure and reliable digital signature verification platform for exchanging electronics documents without putting the user at risk from falsified documents.
What's New in Foxit Reader 6.0
# New Features:
* PDF Creation
- Allows users to quickly and easily create PDF. (not included in addon)
- With one-click, create from Microsoft Word, PowerPoint, and Excel through the Foxit Reader plug-in. (not included in addon)
- High performance PDF conversion from hundreds of file types by:
> Dragging and dropping the document into Foxit Reader.
> Using the Foxit Reader create From File capability.
> Right mouse clicking on the file.
- Convert hardcopy documents into PDF with the create From Scanner functionality.
- Extend any application with print capabilities to include PDF conversion through the included Foxit Reader PDF Printer (PDF print driver).
- Cut and paste content via the Windows clipboard into a new PDF by using the From Clipboard feature.
* Ribbon-Based Toolbar
- New user interface with a ribbon-based toolbar based on Microsoft Office 2013 (Office 15) design is more intuitive and provides users with a familiar user experience.
* Read and Search PDF Portfolios
- Open and read PDF portfolios and perform searches either within a single PDF file or across all the PDF files in the portfolio.
* Whitelist Trusted URLs for Form Submission
- Enables users to create and maintain a whitelist of the trusted URLs when submitting form online to manage the file access.
* Create and Insert Stamps
- Allows users to create and insert stamps into their PDF documents and forms, by selecting from a choice of pre-made stamps, creating static custom or dynamic stamps.
* PDF Sign
- Allows users to sign documents with their own handwriting. Signatures can be created from an image of your signature or by writing it yourself on touch enabled desktop systems or tablets. Users can quickly and easily manage, place, and apply these signatures.
* Plug-in Manager
- Adds plug-in Manager which shows a list of installed plug-ins and the relevant information.
# Feature Enhancements:
* Comments Summary
- Supports sorting comments by checkmark status, setting current properties of any comment as default, and deleting comment by batch. Plus, the Note comment now supports to be printed.
* Booklet Printing
- Allows users to print multipage PDF in booklet format.
* Run Script Right Control
- Supports to control the right of running Script for better PDF protection.
********* About this addon package ************************
Foxit Reader comes with the following characteristics:
  • No ASK toolbar
  • no V9.com
  • No Foxit Search Bar
  • Only 1 Start Menu shortcut
  • Removed Add Banner in foxit reader window.
  • Associate as default PDF file handler
  • English, neutral, German, Spanish, French, Dutch, Italian, Portuguese_Brazilian & Turkish. (unneeded lang files are automatically removed)
  • Default skin is blue*
  • Included plugins: Firefox Plugin & Foxit Spell Checker.
  • Includes PDF virtual printer
To change skin/lang/Toolbar, see instruction in [Remark] section of inf
To view PDF web address in browser, navigate to this address in IE/Firefox/Opera/SeaMonkey/Pale Moon:
http://cdn04.foxitsoftware.com/pub/foxit/manual/en_us/FoxitReader54_Manual.pdf
You should be able to view the pdf file within it's browser, instead of prompt to download or open with Foxit Reader.
Spanish version hosted by luis here
FoxitReader6.1.1.1031_Addon.cab
Size: 54.86 Mb (57,752,117 bytes)
MD5: 4EEC9D57831503D8F6413DE050163AB4
Compatible with win7 x86 (just extract the .cab to get the silent installer.exe)
To avoid registry conflict:
And hence to stay problem-free with this addon, ensure no existing pdf reader is currently installed. If already have an existing one, please uninstall it first. Reboot if necessary. Then install this addon.
If you wish to use another pdf reader app, pls uninstall this one first.
Edited by Geej
  • Replies 147
  • Views 51.2k
well The addon work perfect.I want to remove prompt "Do you want to install Kels' UberPacK on your computer?" to use it at T-23 installation.How to do?
The message prompt comes from the directive BeginPrompt=
Text search this string and comment out the directive like this:
;BeginPrompt=
Try to ask Kels directly if in doubt. The above suggestion is just my quick guess
Uploaded to esnips
If you know why my profileitems does not work during unattended install, please let me know :)
It only works during manual install when right-click, install.
Hope esnips works for you
  • 5 weeks later...
Hi, Geej
Foxit Reader 4.3.0.1110 released :thumbsup_anim:
Can you make foxit reader comes with the following same characteristics:
* No ASK toolbar
* Only 1 Start Menu shortcut
* Removed Add Banner in Foxit reader window.
* Associate as default PDF file handler
and with the following Critical Add-ons
* GDI + Module
* JPEG2000/JBIG Decoder
* JavaScript Support
* Eastern Asian Language
* Spell Checker
* Firefox Plugin*
Edited by oguz
Thanks for the quick update update. This is one of the most successful work on the forum :)
Edited by oguz
Thanks for your kind compilment. Just trying to do my best and also learning along the way... Cheers :welcome:
  • 5 weeks later...
  • 4 weeks later...
  • 4 weeks later...
Foxit Reader 5.0.1.0523 is released (05/26/11) :)
* Displays the PDF files in the Windows Explorer as the thumbnails if Foxit Reader has been set as the default PDF viewer.
This is super :)
Edited by oguz
This is super :)
Updated to Foxit Reader 5.0.1.523. This is a relatively new and big package to make and I have included user_manual in pdf format. Hence overall cab filesize looks 'big'. Thanks for your interest.
Edited by Geej
Thank u for update. But, why u make "No plugins" an addon?
Can u make yes plugins an addon?
Eastern Asian Language Support
JavaScript Support
GDI + Module
OnDemandCM
Etc...
