wolfsoul Posted August 31, 2010 Posted August 31, 2010 Ok Ive seen part of them.. Ive seen full suitesBut can separate powertoys be added to unattended xp setupWell the one Im interested most in is the color panel... think someone once told me how to do it but I can't recall or find it anymoreMight have been ROE not sure.. and don't know if it can be done SVCPACKAnyone any idea or help? Quote
ricktendo Posted August 31, 2010 Posted August 31, 2010 Correct ColorCPL will not install via SVCPACK, I made a silent installer if you execute during SVCPACK with the -ai switch it will then install via ROExhttp://www.mediafire.com/?sro5wbv52l0lkpd/Moved Quote
wolfsoul Posted August 31, 2010 Author Posted August 31, 2010 Correct ColorCPL will not install via SVCPACK, I made a silent installer if you execute during SVCPACK with the -ai switch it will then install via ROExhttp://www.mediafire...sro5wbv52l0lkpd/MovedThnx man.. so I jsut add this manually to svcpack (the inf?) and it will execute(Blah NIS gave false postive?) Quote
ricktendo Posted August 31, 2010 Posted August 31, 2010 Its a 7zip SFX, you can use 7zsplit to take apart and remakeIf you double click it, it installs normal, if you run it with -ai it will add runonceex reg entry...here is config.txt;!@Install@!UTF-8!RunProgram="\"Microsoft Color Control Panel Applet for Windows XP.msi\" LAUNCHREADME=No LAUNCHWINCOLOR=No /qn /norestart";Delay installAutoInstall="hidcon:reg add HKLM\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnceEx\\cpl /ve /d \"Color Control Panel Applet\" /f"AutoInstall="hidcon:reg add HKLM\\Software\\Microsoft\\Windows\\CurrentVersion\\RunOnceEx\\cpl /v 1 /d %%S\\ColorCPL.exe /f"GUIMode="2";!@InstallEnd@!Make a addon from it, put it in a svcpack folder and create a entries_something.ini file with[general]builddate=2010/08/31description=Microsoft Color Control Panel Applet for Windows XPlanguage=Englishtitle=Microsoft Windows Color Managementversion=1.0.177.0website=http://www.microsoft.com/downloads/details.aspx?familyid=1E33DCA0-7721-43CA-9174-7F8D429FBB9E[EditFile]SVCPACK.INF,SetupHotfixesToRun,AddProgram[AddProgram]ColorCPL.exe -ai Quote
wolfsoul Posted August 31, 2010 Author Posted August 31, 2010 I appreciate the helpHowever.. from what I learned before.. decompress svpack.in_, add exe with switch then makecabe and replace will work too I beleive(AMC taught me alot of stuff.. from Project Alchemist/Alchemist revolutions) Quote
