nagireddy Posted September 21, 2010 Posted September 21, 2010 (edited) Hi RIS Server Configuration ProblemDesktop Details HDD 80 GBPartitions: C Drive (30 GB) D Drive 50 GBOS Installed: Windows XP SP3 F12 Supportable Mother Board (Boot from Network Support) Problem: I Am Unable to Reinstall XP in C Partition by Using RIS Server.It is Formatting entire 80 GB HDD Installing the OS through RIS Server.I did some modification in ristndrd .sif, I tested it is prompting Press enter to install in selected partitions. Press D to delete the selected partitions. Press C: to create Partitions.1st I deleted all Partitions, created 30 GB & 50 GB partitions I installed OS in 30 GB .Every thing is finished successfully through RIS Server .i login XP I opened the C Drive checked System Files. & opened the D drive checked free space & I kept some documents. Again I started the OS reinstallations through RIS Server.This time it is not asking any options. Simply searching entire HDD and started OS Installation in D Drive and finished successfully.Here the problem I am unable to install OS in C Drive RIS Server Details: windows 2003 Server.RIS Answer File Fully Automated .Here I am Attaching the .Sif File.some one please help this issue thanks Nag Edited September 24, 2010 by nagireddy Quote
nagireddy Posted September 27, 2010 Author Posted September 27, 2010 Hello i Think It is allready configured in .Sif answer file Quote
Kelsenellenelvian Posted September 27, 2010 Posted September 27, 2010 wtf? You think or it IS???Please just remove your serial and attach your .sif file Quote
