Posted (edited)
Chances are you're here because you're running Windows Vista and want to do one of two things. Install a second OS or manage your registry entries without directly editing the BCDEdit file. As you likely now realize, Windows Vista has made this task somewhat complicated for most users. VistaBootPRO was developed to make changes to the Windows Vista Boot Configuration Data (BCD) registry quickly and easily, doing the job in a fraction of the time it would take using the alternative. The only other way to edit the BCD is to use the command prompt application "bcdedit.exe," located in the Windows\system32 folder of Windows Vista, which requires users to become familiar with the ins and outs of the bcdedit.exe switches and options, leaving many frustrated users in its path. VistaBootPRO allows users to easily and neatly organize registry entries from within all flavors of Windows.
View Settings
Manage Entries
Advanced
Backup/Restore
PROnetworks VistaBootPRO
Edited by cro-man
