Posted October 7, 201014 yr Hi,how can i intigrate the downloaded driver packs? Do i have to extract the 7ziped downloads?
October 7, 201014 yr Yeah you have to extract the file and then when pressing 'Add Drivers', just select the folder you extracted.
October 7, 201014 yr Author Yeah you have to extract the file and then when pressing 'Add Drivers', just select the folder you extracted.Okay thx. Ive tryed this but it doesnt work but i think i know the problem. Ive started W7T from a folder on desktop and the desktop has a folder redirection on my server. Now ive started W7T from a local drive it works
