Posted October 14, 201014 yr Why don't add to Tools Manager a function to merge 2 swm file,not only for split Thx!
October 14, 201014 yr Because if you have swm files then your source has already been modified and its always suggested to use a new source.
October 14, 201014 yr Author by the way how to merge 2 swm files?I need imagex.exe?need a syntax? By example if i have two file : "install.swm" and "install2.swm" which is the command to merge together in only one WIM file?Thx and please help me.
October 14, 201014 yr FIRST Google result:http://www.verboon.info/index.php/2009/10/splitting-and-merging-image-files-with-imagex/Seems rather easy to me.I still would like to know what your mod program was.
October 14, 201014 yr Like Kels said it's always best to use a fresh source, however you can check the WIM Manager tool and try the merge button, if it's not there then i may add the function for the next version.
November 11, 201014 yr I do it all the time with this command:imagex /ref install*.swm /check /export install.swm 1 install.wim "name of image"
