koolx Posted November 7, 2010 Posted November 7, 2010 (edited) I got an XP theme that adds a grey background color to every application, including Word. When I print a document, the grey background prints also, which is undesirable. How can I change the background color of Word (to white) and make that the default color without changing any part of the theme? Edited November 7, 2010 by koolx Quote
ricktendo Posted November 7, 2010 Posted November 7, 2010 Woa, a theme that changes the color of the page? Quote
Kelsenellenelvian Posted November 7, 2010 Posted November 7, 2010 please give me a link to the theme... Quote
koolx Posted November 7, 2010 Author Posted November 7, 2010 please give me a link to the theme...Hi, Kelsenellenelvian. The link is:http://vladimir0523.deviantart.com/gallery/#/d1wuv19Hope you can help me in resolving this issue.... Quote
Kelsenellenelvian Posted November 8, 2010 Posted November 8, 2010 I will install xp tommorow and try it out.What version of office? Quote
koolx Posted November 8, 2010 Author Posted November 8, 2010 I will install xp tommorow and try it out.What version of office?Its 2003 version. Quote
koolx Posted November 10, 2010 Author Posted November 10, 2010 I will install xp tommorow and try it out.What version of office?Any ideas on how to fix this? Quote
Kelsenellenelvian Posted November 10, 2010 Posted November 10, 2010 Yeah I found 1 wayYou need to go into customization and then advanced and change the background of ALL windows to a lighter color.Only solution I found. Quote
koolx Posted November 11, 2010 Author Posted November 11, 2010 Yeah I found 1 wayYou need to go into customization and then advanced and change the background of ALL windows to a lighter color.Only solution I found.I know this. But its not a solution because when I change the background of ALL windows to white, the background color of the theme wil also change from grey to white. Thats the problem. I want to be able to keep the theme's backgreound color (grey). But doing so will also change Word's background color from white to grey. Theres got to be a way to keep the theme's background color without changing Word's background color. ....... Quote
