Posted March 17, 200717 yr Ok, how do i use nlite, i downloaded it, instaleld it and now its at the part where it says locating windows instalation, what folder do i choose?
March 17, 200717 yr I started a new topic for ya...Here are some links for ya:http://www.msfn.org/board/index.php?showtopic=28005http://www.ryanvm.net/msfn/nlite.html
March 18, 200717 yr Author Im starting to thing im a huge dumbass, i didnt understand that.... and i dotn have an xp cd, so i cant use it? Edited March 18, 200717 yr by consume
March 18, 200717 yr Author You need XP, 2000 or 2k3There is a VLite for Vista Where should my "windows source" be then?
March 18, 200717 yr Make a NEW folder and then highlight all the windows CD rom or DVD files and copy them to itName the foleder C:\XPCD or C:\VISTADVD and browse to it with nLite or vLite and begin customizing
March 18, 200717 yr Author consume, how do you get Windows loaded on your computer then?Well, simple, it came preinstaleld with my pc. Edited March 18, 200717 yr by consume
March 18, 200717 yr Well, simple, it came preinstaleld with my pc, jeez some of u guys are asses.Please refrain from insulting other members, cygnus didn't mean to offend you with his question.
March 18, 200717 yr Well, simple, it came preinstaleld with my pc, jeez some of u guys are asses.Interesting. :ermm: Didn't mean to offend you, I was asking a simple question. Sarcasm is hard to express on the internet, and I don't even attempt it.Did it come with OEM restore discs? If so, you can't use nLite unless you can get the I386 folder and all the contents of it. But also keep in mind, if you can manage to get an nLitened install disc from a retail XP disc, your going to have to get all the drivers and stuff. It becomes a real pain to get them all. Edited March 18, 200717 yr by cygnus
March 18, 200717 yr Author Interesting. :ermm: Didn't mean to offend you, I was asking a simple question. Sarcasm is hard to express on the internet, and I don't even attempt it.Did it come with OEM restore discs? If so, you can't use nLite unless you can get the I386 folder and all the contents of it. But also keep in mind, if you can manage to get an nLitened install disc from a retail XP disc, your going to have to get all the drivers and stuff. It becomes a real pain to get them all.No, it didnt come with the 7 restore discs but i recently got them mailed to me. I can get the folders from there?
March 18, 200717 yr Depends on the method the OEM used, but I doubt it. OEM restore discs are friendly that way.
March 19, 200717 yr you really need to source an original cd for a good outcome, weither you buy this or not is upto you. an untouched version is what you need as an original image
August 10, 200816 yr look for C:/I386 You might be able to use that. Warning!! Copy that folder. DO NOT use the original. Something bad could happen. Edited August 10, 200816 yr by Christopher
