Posted March 20, 200718 yr Ok. You know when you're using IE and you click on a link.. there's a click sound or button sound. I want to get that click sound to put in my project. do you know where to extract it? or since i'm not good with computers, can you give me if you have it? Thanks!if you can't, then it's ok though.. just asking if you guys can help me. THanks!!
March 20, 200718 yr Author Kelsenellenelvian said: :\Windows\Media\Anyways here is the specific one you asked for =great! thanks! very much appreciated! :thumb_yello:
March 20, 200718 yr Author and also! last one please.. the vista boot sound, i need it also..i try to look in windows/media but i cant seem to find it.. i've listen to all the wav sounds but there's no vista boot sound.. thx
March 20, 200718 yr I got this startup sound from Cygnus (the reason you cant find it in Media is its located in a DLL, I forgot the filename) Quote http://mihd.net/8vik6mThere ya go Enjoy
March 20, 200718 yr cygnus said: It's located in imageres.dll in C:\Windows\System32Used reshack to get it
