  • Replies 84
  • Views 40.1k
Querido Amigo  luis  ha salido unsa nueva version que es la 4.51 podias subirlo por favor
podrias aumentar lo siguente si no te molesta
IrfanView Shell Extension Plug-In:
Both x86&x64 included.
http://www.irfanview.net/plugins/irfanview_shell_extension_plugin.exe
SHA-256: b9828e236b26626b46fe20ad31208140fc572819ba86c2cba75cbd2c7724ebef
http://www.irfanview.net/plugins/irfanview_shell_extension.zip
SHA-256: 2112f85a917b2eca90eaa047a8c3b22e0157f13e83971aee679d955b2ff1047d
y los siguentes temas
Creator: Sepp, Button sizes: 16x16, 24x24, 32x32, 48x48, 64x64
Creator: Icons by Axialis Software/Assembled by Paul Kibe, Button sizes: 16, 24, 32
Creator: Maxelo, Button sizes: 24x24, 32x32, 48x48, 56x56, 64x64
Creator: Icons by IconShock/Assembled by Paul Kibe, Button sizes: 24, 32
Creator: pixlers.at, Button sizes: 25x25
otra pegunta sacaras para 64 Bits tambien
  • 8 months later...
  • 6 months later...
On 1/29/2020 at 8:09 AM, luis said:
Hola Geodasoft, acabo de pobar y no tengo problemas puedo ver sin error el tipo de imagenes .webp. Ejecutaste la instalacion del programa como administrador? esto para registrar los plugins
creo que el problema es por que uso XP
  • luis changed the title to IrfanView 4.56 Silent Español x32
  • luis changed the title to IrfanView 4.57 Silent Español x32
  • luis changed the title to IrfanView 4.58 Silent Español x32
  • luis changed the title to IrfanView 4.59 Silent Español x32
