Recuva is a freeware Windows utility to restore files that have been accidentally deleted from your computer.
This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera
memory cards or MP3 players. It will even bring back files that have been deleted by bugs, crashes and viruses! Recuva is a new file recovery
tool that will unerase files that you have mistakenly deleted from your computer. It's fast, small and will run from a USB drive.
It also supports most digital cameras card formats, so you can restore those images you accidentally deleted! Turn off any applications
you don't need, if you are trying to recover files from a media card, stop using that card immediately.
Ideally install Recuva before you need it, as just browsing the internet and downloading the installer creates a huge number of temporary
files and any one of them could over write the file you are trying to recover. When you need it, just Scan the drive the file was on.
Runs on Microsoft Windows 7, Vista, XP, 2003 and 2000 (32-bit & 64-bit versions).
Multilingual
Changes in Recuva v1.39.509 (20 Dec 2010):
Fixed bug that caused "Unable to read MFT" error.
Improved support for exFAT drives.
Improved support for Windows 7.
Added mnemonics to the Wizard.
Extended logging for Windows 7 64-bit.
Added link to Online Help.
Fixed bug that could cause analysis fail on U3 drives.
Minor bug fixes.
Homepage: http://www.recuva.com
http://www.mediafire.com/file/ibgqdui78ucbzbm/Kels_Addon_Recuva_1.39.509.rar
1.44 megs 2ee8253603d19710edf2152607e21619 MD5
DOES NOT CONTAIN THE GOOGLE-WARE!!!
