Posted December 30, 201014 yr Hi,I plane preparing an Unatended Windows 7 64-bits and my using machine run Windows 32-bits. It is possible to prepare an Unatended Windows 64-bits on a machine using Windows 32-bits?Or, the using machine must run Windows 64-bits too?Regards
December 30, 201014 yr Depends on all what you are doing.Prepping a ua.xml file? Sure you can do that.
December 30, 201014 yr Yes you can generate a xml with WSIM, but dont go updating the catalog (clg) files
