Posted January 21, 201114 yr Due to a bug I have had to disable the Unattended Creator, whilst I will be fixing it I wi be redesigning it and adding options, does anyone want a specific feature adding to it?
January 24, 201114 yr Due to a bug I have had to disable the Unattended Creator, whilst I will be fixing it I wi be redesigning it and adding options, does anyone want a specific feature adding to it?Legolash2o, Here are features I would like to suggest:Set Network Location to HomeDisable Windows Error ReportingSet Google as Search ProviderWill work in all versions of Win7,Starter, Basic,etc,etc.Will work on x86 or x64 bit versionsThanks :thumbsup_anim:
March 19, 201113 yr Sir i want to modify windows 7 installation setup like- Background,icon,font style,etc. Sir please help me to find applications to modify it with your help it is possible.
March 22, 201113 yr You can use the [ProcessesToRunBeforeIntegration] [ProcessesToRunAfterIntegration] Section, to run the reshaker.exe ect ectCiao.
April 18, 201113 yr Specific features? Let see....I would like to see:..Ability to input product key as well as skip product key..Option to Accept EULA..Option to Skip wireless set..Option to Select the current Windows Edition to install..Option to Skip user creation and Autologon User..Network Location Options..Options for Protect your PC..Inputs for Username and Password..Inputs for Full Name, Organization, and Computer Names..Options for UI Language, Time and Currency, Keyboard Input,and Time Zone.Whew!Cheer,MR. OOKIE :icon_cool:
May 1, 201113 yr Author Get your last request in for the Unattended Creator before i close this thread and begin work on it. Will be today.EDIT: Closed. Edited May 1, 201113 yr by Legolash2o
