  • 9 years later...
Following are some steps to delete record from MS Access Database
Open the table in Datasheet View or form in Form View.
Select the record or records that you want to delete.
To select a record, click the record selector next to the record, if the record selector is available.
To extend or reduce the selection, drag the record selector (if it is available), or press SHIFT+DOWN ARROW or SHIFT+UP ARROW.
Press DELETE, select Home > Records > Delete, or press Ctrl+Minus Sign (-).
I hope this helps!
Leo Clarke
